  3. VerilogA $limit with spectre
  • Views 12257
camilloS
camilloS over 5 years ago
Dear Cadence community,
is there any roadmap to support in future with Spectre the full functionality of $limit() function in Verilog-A? Is there any alternative to that?
Thank you.
    I took a look at the LRM and I'm a bit surprised that you'd need the unsupported features of $limit. As far as I can tell, nobody has yet requested that these are supported.
    I suggest that if you need them, you contact customer support with an example of a model that relies upon using a built-in function or a user-defined function to control the limiting (I assume that's what you're missing). Then this could be raised with R&D.
