  3. "the following branches form a loop of rigid branches"
  • Subscribers 136
  • Views 4126
Jose Sarmento
Jose Sarmento over 5 years ago
Hello all,
I'm designing an xpair for a sinusoidal oscillator, and while doing an ac analysis, the following error appears:
The circuit is as follows:
From the error, it is plain that the AC source V1 is causing the trouble, but I can't understand why exactly.
Thank you
    The reason is that during DC the inductors are shorted, so that means that the voltage source V1 is shorted - which means you would have an ill-conditioned matrix. Even though the voltage source might…
    The reason is that during DC the inductors are shorted, so that means that the voltage source V1 is shorted - which means you would have an ill-conditioned matrix. Even though the voltage source might be 0V at DC, the equations would still have this problem.
    Since your inductors are (presumably) ideal analogLib inductors, I would suggest setting the resistance parameter of one or other of them (or both) to a small value (e.g. 1mOhm; in general you should not use smaller resistor values than 1mOhm as this can lead to convergence difficulties). That will prevent the problem.
  • Jose Sarmento
    Jose Sarmento over 5 years ago in reply to Andrew Beckett
    Interesting, did not think that through. Your suggestion fixed it, thank you so much!
