  3. How do I set transient strobeoutput to "all" in AMS simulation...
  • Views 2403
How do I set transient strobeoutput to "all" in AMS simulation?
Nader Fathy
Nader Fathy over 5 years ago
I am running a transient simulation for ADC ENOB calculation purposes. In Spectre, there is an option called "strobeoutput" which I set to "all" to force the transient simulation to calculate the desired periodic points avoiding FFT interpolation errors, and at the same time calculate the necessary points needed for simulation accuracy requirements.
However, on simulating a Verilog model with AMS simulator, I can't find "stobeoutput" option. Is there a way to enable this option and set it to "all"?
Virtuoso: IC6.1.8-64b.500.15
Spectre: 19.1.0.541.isr14
xrun 19.09-s016
Kindest Regards,
Nader Fathy
    Hi Nader, For now, go to the Misc tab of the Transient options form and in the additionalParams field, type strobeoutput=all . There is an enhancement CCR 2028903 which I've just chased to get this added…
    Hi Nader,
    For now, go to the Misc tab of the Transient options form and in the additionalParams field, type strobeoutput=all. There is an enhancement CCR 2028903 which I've just chased to get this added into the normal AMS transient options.
  • Nader Fathy
    Nader Fathy over 5 years ago in reply to Andrew Beckett
    Thank you Andrew, it worked!
    Kindest Regards,
    Nader Fathy
