  3. [ Liberate ] Cells do not have -extsim_model parameter specified...
  • Replies 34
  • Subscribers 136
  • Views 29529
[ Liberate ] Cells do not have -extsim_model parameter specified in define_leafcell command
iamKarthikBK
iamKarthikBK over 5 years ago
I am trying to characterize a standard cell library, but liberate gives me the following errors.
WARNING (LIB-40): (set_var): Ignored the invalid value '$model' specified for 'extsim_model_include'. It should be set to an absolute file path.
INFO (LIB-511): (define_leafcell): Leafcell 'N_18_MM' (instance) has been identified with pin_position (0 1 2 3) mapped to (D G S B).
LIBERATE parameter "extsim_exclusive" set to "1"
INFO (LIB-511): (define_leafcell): Leafcell 'P_18_MM' (instance) has been identified with pin_position (0 1 2 3) mapped to (D G S B).
LIBERATE parameter "simulator" set to "spectre"
LIBERATE parameter "char_library_skip_var_list" set to ""
Start Characterizing Library at (Wed May 19 00:36:13 IST 2021)
WARNING (LIB-909): (read_spice): Could not find a model/subckt definition for instance 'c' named 'mim_va' with '2' terminals.  Liberate will attempt to guess the device type. Read the models in read_spice or use define_leafcell to map the name to a model/subckt and rerun.
WARNING (LIB-909): (read_spice): Could not find a model/subckt definition for instance 'r1' named 'res_va' with '2' terminals.  Liberate will attempt to guess the device type. Read the models in read_spice or use define_leafcell to map the name to a model/subckt and rerun.
WARNING (LIB-909): (read_spice): Could not find a model/subckt definition for instance 'rs' named 'reshr_va' with '2' terminals.  Liberate will attempt to guess the device type. Read the models in read_spice or use define_leafcell to map the name to a model/subckt and rerun.
WARNING (LIB-909): (read_spice): Could not find a model/subckt definition for instance 'rs' named 'resnp_va' with '2' terminals.  Liberate will attempt to guess the device type. Read the models in read_spice or use define_leafcell to map the name to a model/subckt and rerun.
WARNING (LIB-909): (read_spice): Could not find a model/subckt definition for instance 'rs' named 'respp_va' with '2' terminals.  Liberate will attempt to guess the device type. Read the models in read_spice or use define_leafcell to map the name to a model/subckt and rerun.
WARNING (LIB-933): To enable automatic leaf-cell recognition, the variable 'extsim_model_include' is required.
INFO (LIB-956): (read_spice): Reading file: 'dut.scs'.
INFO (LIB-955): (read_spice): Further occurrences of the preceding message will be suppressed.
INFO (LIB-940): The parser has identified the following leaf cells. Review these for missing or incorrect settings and if needed, add them to your Tcl script and rerun.
INFO (LIB-906): (AUTO): define_leafcell -type black_box -pin_position {0 1 2} l_slcr20k_rf
INFO (LIB-906): (AUTO): define_leafcell -type c -pin_position {0 1 2} mimcapm_rf
INFO (LIB-906): (AUTO): define_leafcell -type c -pin_position {0 1} mimcaps_mm
INFO (LIB-906): (AUTO): define_leafcell -type nmos -pin_position {0 1 2 3} n_l18w500_18_rf
INFO (LIB-906): (AUTO): define_leafcell -type nmos -pin_position {0 1 2 3} n_l34w500_33_rf
INFO (LIB-906): (AUTO): define_leafcell -type nmos -pin_position {0 1 2 3} n_po7w500_18_rf
INFO (LIB-906): (AUTO): define_leafcell -type nmos -pin_position {0 1 2 3} n_po7w500_33_rf
INFO (LIB-906): (AUTO): define_leafcell -type pmos -pin_position {0 1 2 3} p_l18w500_18_rf
INFO (LIB-906): (AUTO): define_leafcell -type pmos -pin_position {0 1 2 3} p_l34w500_33_rf
INFO (LIB-906): (AUTO): define_leafcell -type pmos -pin_position {0 1 2 3} p_po7w500_18_rf
INFO (LIB-906): (AUTO): define_leafcell -type pmos -pin_position {0 1 2 3} p_po7w500_33_rf
INFO (LIB-906): (AUTO): define_leafcell -type diode -pin_position {0 1} vardiop_rf
INFO (LIB-906): (AUTO): define_leafcell -type black_box -pin_position {0 1 2} varmis_18_rf
INFO (LIB-907): (AUTO): define_leafcell -element -type c -pin_position {0 1} mim_va
INFO (LIB-943): Finished reading netlist(s) at May 19 00:36:13.
INFO (LIB-711): Feature 'Virtuoso_Multi_mode_Simulation' exists in the license pool. The parameter 'spectre_use_mmsim_token_license' will be set to '1'.
INFO (LIB-1008): (char_library): This LIBERATE release was qualified with MMSIM version '' but newer version '19.1.0.396.isr8' was detected. If MMSIM-related issues are found, update to the qualified MMSIM version and re-run.
INFO (LIB-966): Using Spectre version 19.1.0.396.isr8 located at: /home/installs/SPECTRE191/tools/bin/spectre.
*Info* Use temporary directory '/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/lowpower/liberate'.
LIBERATE parameter "extsim_deck_dir" defaulted to cad19:/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/lowpower/liberate/decks.cad19.T20210519003610741304S0014229
*Error* (char_library) : set_var extsim_use_leaf_cell is enabled, but
 not all leaf_cells have -extsim_model parameter defined. Since set_var extsim_model_include
 is not used.  Cannot continue, exiting.
*Note* : The following cells do not have -extsim_model parameter specified in define_leafcell command.
      : N_18_MM
      : P_18_MM
Peak memory usage:          340 MB
Peak virtual memory usage:  303 MB
Peak physical memory usage: 37 MB
Wall time      :    0.00 hours (3.00 seconds)
LIBERATE exited on cad19 at Wed May 19 00:36:13 2021
My char.tcl file is as follows:
define_template -type delay -index_1 {61.75 158.9 794.1} -index_2 {18.732 37.464 74.928} delay_3x3
define_template -type power -index_1 {61.75 158.9 794.1} -index_2 {18.732 37.464 74.928} power_3x3
define_template -type constraint -index_1 {61.75 158.9 794.1} -index_2 {18.732 37.464 74.928} constraint_3x3
set model "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/core_rf_v2d4.lib.scs"
set_operating_condition -voltage 0.3 -temp 25
set_var extsim_model_include \$model
define_leafcell -type nmos -pin_position {0 1 2 3} N_18_MM
define_leafcell -type pmos -pin_position {0 1 2 3} P_18_MM
read_spice -format spectre {dut.scs}
define_cell \
-input {in} \
-output {out} \
-delay delay_3x3 \
-power power_3x3 \
-constraint constraint_3x3 \
{INVX1}
define_cell \
-input {a b} \
-output {y} \
-delay delay_3x3 \
-power power_3x3 \
{NAND2X1 NOR2X1 AND2X1 OR2X1 XOR2X1 XNOR2X1}
char_library -extsim spectre
write_ldb lowpower.ldb
write_library lowpower.lib
I am using UMC's 180nm FDK and the MOS devices are named as N_18_MM and P_18_MM for nMOS and pMOS respectively.
I have a feeling that there's something wrong with my .tcl file
How do I go about this?
Thanks in advance!
  • Guangjun Cao
    Guangjun Cao over 5 years ago +1
    Based on the history of your other post, I am guessing your netlist is created from av_extracted view. Very likely, the instances' name for the leafcells does not have "x" prefix, when the netlist is created…
  • iamKarthikBK
    iamKarthikBK over 5 years ago in reply to Guangjun Cao
    Guangjun Cao said:
    please share the line for instance 'M0' in your netlist.
    M0 out#5 in#6 gnd#1 gnd#2 N_18_MM L=1.8e-07
    + W=2.4e-07 effW=2.4e-07
    M1 out#2 in#4 avC5 vdd#1 P_18_MM L=1.8e-07
    + W=3.18e-06 effW=3.18e-06
    ^ This is the inverter netlist.
    Guangjun Cao said:
    share all your read_spice commands
    read_spice {netlist/INVX1.sp netlist/AND2X1.sp netlist/NAND2X1.sp netlist/OR2X1.sp netlist/NOR2X1.sp netlist/XOR2X1.sp netlist/XNOR2X1.sp}
    Guangjun Cao said:
    full logfile
    ROOT_DIR = /home/installs/LIBERATE192
    exepath = /home/installs/LIBERATE192/tools/bin
    Host : cad19 x86_64 Linux 2.6.32-696.el6.x86_64
    LIBERATE Library Characterization Platform (x86_64)
    Release dev, compiled by vficcm on Tue Sep 10 06:33:00 PDT 2019
    * Copyright (c) Cadence Design Systems, Inc. 2006 - 2021. *
    * All rights reserved. *
    * This program contains confidential and trade secret information *
    * of Cadence Design Systems, Inc. and is protected by copyright *
    * law and international treaties. Any reproduction, use, *
    * distribution or disclosure of this program or any portion of it, *
    * or any attempt to obtain a human-readable version of this *
    * program, without the express, prior written consent of *
    * Cadence Design Systems, Inc., is strictly prohibited. *
    * Cadence Design Systems, Inc. *
    * 2655 Seely Avenue *
    * San Jose, CA 95134, USA *
    Copyright notices for Open Source and Third Party Tools used by this
    software can be viewed at <cds_inst_dir>/doc/liberate/thirdpartyinfo/Notices.txt
    LIBERATE started on cad19 at Wed May 19 17:23:28 2021
    Command line arguments: 'tcl/char.tcl'.
    ALTOSHOME set to '/home/installs/LIBERATE192'.
    Server ID : T20210519172328944111S0002333
    LIBERATE parameter "slew_lower_rise" set to "0.2"
    LIBERATE parameter "slew_upper_rise" set to "0.8"
    LIBERATE parameter "slew_lower_fall" set to "0.2"
    LIBERATE parameter "slew_upper_fall" set to "0.8"
    LIBERATE parameter "measure_slew_lower_rise" set to "0.2"
    LIBERATE parameter "measure_slew_upper_rise" set to "0.8"
    LIBERATE parameter "measure_slew_lower_fall" set to "0.2"
    LIBERATE parameter "measure_slew_upper_fall" set to "0.8"
    LIBERATE parameter "max_transition" set to "6.175e-08"
    LIBERATE parameter "extsim_model_include" set to "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs"
    INFO (LIB-511): (define_leafcell): Leafcell 'N_18_MM' (element) has been identified with pin_position (0 1 2 3) mapped to (D G S B).
    INFO (LIB-511): (define_leafcell): Leafcell 'P_18_MM' (element) has been identified with pin_position (0 1 2 3) mapped to (D G S B).
    LIBERATE parameter "spectre_pwr" set to "0"
    Start Characterizing Library at (Wed May 19 17:23:31 IST 2021)
    ERROR (LIB-926): The program will terminate because the definition of the sub-circuit or model for instance 'M0' could not be found. Run the following checks in the given sequence: the subcircuit or model is loaded, the first line in the model file is empty or has a comment, and the netlist syntax is correct. If no problem is found in these checks, use the 'define_leafcell' command to define the sub-circuit or model, and rerun Tcl
    INFO (LIB-956): (read_spice): Reading file: 'netlist/INVX1.sp'.
    INFO (LIB-956): (read_spice): Reading file: 'netlist/AND2X1.sp'.
    INFO (LIB-956): (read_spice): Reading file: 'netlist/NAND2X1.sp'.
    INFO (LIB-956): (read_spice): Reading file: 'netlist/OR2X1.sp'.
    INFO (LIB-956): (read_spice): Reading file: 'netlist/NOR2X1.sp'.
    INFO (LIB-956): (read_spice): Reading file: 'netlist/XOR2X1.sp'.
    INFO (LIB-956): (read_spice): Reading file: 'netlist/XNOR2X1.sp'.
    Peak memory usage: 335 MB
    Peak physical memory usage: 32 MB
    LIBERATE exited on cad19 at Wed May 19 17:23:31 2021
    Guangjun Cao said:
    the contents of your model wrapper.
    simulator lang=spectre insensitive=yes
    // Last update on 5/26/2005
    // WHAT CONTAINS IN THIS LIBRARY:
    // 1. MM180_REG18_V124.lib.scs
    // (UMC 0.18um Regular Vt 1.8V Mixed Mode process Spice Model )
    // Model Name:
    // N_18_MM ............. 1.8V NMOS Model
    // P_18_MM ............. 1.8V PMOS Model
    // 2. MM180_REG33_V114.lib.scs
    // (UMC 0.18um Regular Vt 3.3V Mixed Mode process Spice Model )
    // Model Name:
    // N_33_MM ............. 3.3V NMOS Model
    // P_33_MM ............. 3.3V PMOS Model
    // 3. MM180_LVT18_V113.lib.scs
    // (UMC 0.18um Low Vt 1.8V Mixed Mode process Spice Model )
    // Model Name:
    // N_LV_18_MM ............. 1.8V NMOS Model
    // P_LV_18_MM ............. 1.8V PMOS Model
    // 4. MM180_LVT33_V113.lib.scs
    // (UMC 0.18um Low Vt 3.3V Mixed Mode process Spice Model )
    // Model Name:
    // N_LV_33_MM ............. 3.3V NMOS Model
    // P_LV_33_MM ............. 3.3V PMOS Model
    // 5. MM180_ZVT18_V121.lib.scs
    // (UMC 0.18um Zero Vt 1.8V Mixed Mode process Spice Model )
    // Model Name:
    // N_ZERO_18_MM ............. 1.8V NMOS Model
    // 6. MM180_ZVT33_V113.lib.scs
    // (UMC 0.18um Zero Vt 3.3V Mixed Mode process Spice Model )
    // Model Name:
    // N_ZERO_33_MM ............. 3.3V NMOS Model
    // 7. MM180_DIODE_V113.mdl.scs
    // (Diode Model)
    // Model Name:
    // DION_MM ............. N+/P-well diode model
    // DIOP_MM ............. P+/N-well diode model
    // DIONW_MM ............ N-well/P-sub diode model
    // 8. MM180_BJT_V112.mdl.scs
    // (BJT Model)
    // Model Name:
    // PNP_V50X50_MM ............. 5umx5um Vetical PNP Model
    // PNP_V100X100_MM ........... 10umx10um Vetical PNP Model
    // 9. MM180_RES_V133.lib.scs
    // (Resistor Models)
    // Model Name:
    // rnnpo_mm ...................Non Salicide N+ poly resistor model
    // rnppo_mm ...................Non salicide P+ poly resistormodel
    // rnhr1000_mm ................Non salicide HR poly resistor model
    // 10. MM180_MIMCAP_V101.lib.scs
    // (MIM capacitor Model)
    // Model Name:
    // mimcaps_mm .................MIM capacitor
    library MyLib
    section tt
    include "./SPECTRE/MM180_LVT18_V113.lib.scs" section=tt
    include "./SPECTRE/MM180_LVT33_V113.lib.scs" section=tt
    include "./SPECTRE/MM180_REG18_V124.lib.scs" section=tt
    include "./SPECTRE/MM180_REG33_V114.lib.scs" section=tt
    include "./SPECTRE/MM180_ZVT18_V121.lib.scs" section=tt
    include "./SPECTRE/MM180_ZVT33_V113.lib.scs" section=tt
    endsection tt
    section ss
    include "./SPECTRE/MM180_LVT18_V113.lib.scs" section=ss
    include "./SPECTRE/MM180_LVT33_V113.lib.scs" section=ss
    include "./SPECTRE/MM180_REG18_V124.lib.scs" section=ss
    include "./SPECTRE/MM180_REG33_V114.lib.scs" section=ss
    include "./SPECTRE/MM180_ZVT18_V121.lib.scs" section=ss
    include "./SPECTRE/MM180_ZVT33_V113.lib.scs" section=ss
    endsection ss
    section ff
    include "./SPECTRE/MM180_LVT18_V113.lib.scs" section=ff
    include "./SPECTRE/MM180_LVT33_V113.lib.scs" section=ff
    include "./SPECTRE/MM180_REG18_V124.lib.scs" section=ff
    include "./SPECTRE/MM180_REG33_V114.lib.scs" section=ff
    include "./SPECTRE/MM180_ZVT18_V121.lib.scs" section=ff
    include "./SPECTRE/MM180_ZVT33_V113.lib.scs" section=ff
    endsection ff
    section snfp
    include "./SPECTRE/MM180_LVT18_V113.lib.scs" section=snfp
    include "./SPECTRE/MM180_LVT33_V113.lib.scs" section=snfp
    include "./SPECTRE/MM180_REG18_V124.lib.scs" section=snfp
    include "./SPECTRE/MM180_REG33_V114.lib.scs" section=snfp
    include "./SPECTRE/MM180_ZVT18_V121.lib.scs" section=snfp
    include "./SPECTRE/MM180_ZVT33_V113.lib.scs" section=snfp
    endsection snfp
    section fnsp
    include "./SPECTRE/MM180_LVT18_V113.lib.scs" section=fnsp
    include "./SPECTRE/MM180_LVT33_V113.lib.scs" section=fnsp
    include "./SPECTRE/MM180_REG18_V124.lib.scs" section=fnsp
    include "./SPECTRE/MM180_REG33_V114.lib.scs" section=fnsp
    include "./SPECTRE/MM180_ZVT18_V121.lib.scs" section=fnsp
    include "./SPECTRE/MM180_ZVT33_V113.lib.scs" section=fnsp
    endsection fnsp
    section diode
    include "./SPECTRE/MM180_DIODE_V113.mdl.scs"
    endsection diode
    section bjt
    include "./SPECTRE/MM180_BJT_V112.mdl.scs"
    endsection bjt
    section res_typ
    include "./SPECTRE/MM180_RES_V133.lib.scs" section=res_typ
    endsection res_typ
    section res_min
    include "./SPECTRE/MM180_RES_V133.lib.scs" section=res_min
    endsection res_min
    section res_max
    include "./SPECTRE/MM180_RES_V133.lib.scs" section=res_max
    endsection res_max
    section mimcaps_typ
    include "./SPECTRE/MM180_MIMCAP_V101.lib.scs" section=mimcaps_typ
    endsection mimcaps_typ
    section mimcaps_min
    include "./SPECTRE/MM180_MIMCAP_V101.lib.scs" section=mimcaps_min
    endsection mimcaps_min
    section mimcaps_max
    include "./SPECTRE/MM180_MIMCAP_V101.lib.scs" section=mimcaps_max
    endsection mimcaps_max
    endlibrary MyLib
    Guangjun Cao said:
    make sure, the first line in the model file is empty or has a comment
    Yes, The first line in the above file has a comment
    Guangjun Cao said:
    check if the devices names in model files and netlist are both in upper case.
    The model file has definations as follows:
    // 0.18um 1.8v/3.3v MIXEDMODE Twin-well technology, 1.8V NMOS Model
    model n_18_mm bsim3v3 type=n
    // 0.18um 1.8v/3.3v MIXEDMODE Twin-well technology, 1.8V PMOS Model
    model p_18_mm bsim3v3 type=p
    But my netlist has them as N_18_MM and P_18_MM (uppercase).
    After changing these to lowercase (in the netlist), the error still exists.
  • Guangjun Cao
    Guangjun Cao over 5 years ago in reply to iamKarthikBK
    you need one more read_spice for model file, or add the model file to the existing read_spice. -element option for define_leafcell may still be needed, based on your netlist syntax.
  • iamKarthikBK
    Thanks, the issue was resolved.
    But I think the characterization was unsuccessfully even though the .lib file was generated.
    Here's the datasheet: https://gist.githubusercontent.com/iamKarthikBK/4f97b17d7bac915da25328ead6e72e05/raw/720ede5bb404fced51602f4515e03739210bcb09/datasheet.txt
    I think the simulator was actually unable to simulate the netlists it read in, and hence the wrong output. Am I correct?
    Here's the complete log file: https://gist.githubusercontent.com/iamKarthikBK/4f97b17d7bac915da25328ead6e72e05/raw/720ede5bb404fced51602f4515e03739210bcb09/liberate_log.txt
    I don't expect anyone here to go through the entire thing, I will reach out to imec.be for support, but if something seems obvious in this case, then kindly point it out.
    Yes I did not specify the areas for any of the cells.
    I think part of the error (or the entire thing) is because I have not added '$ALTOSHOME/tools.lnx86/spectre/bin' to my environment PATH. Am I right?
  • Guangjun Cao
    Per logfile, the simulation failed. you can do a standalone simulation, using,
    spectre xxxxx/sim.sp. then check the logfile. the sim.sp file is in those directories flagged in
     /home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/lowpower/liberate/altos.*/
  • iamKarthikBK
    Do I need to specify the model's red_spice in a separate line because it's a .scs file and the other netlists are .sp files?
    [VLSI_ANALOG@cad19 liberate]$ spectre /home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/lowpower/liberate/altos.cad19.T20210519174925563390S0004537.0/sim.sp
    Spectre (R) Circuit Simulator
    Version 19.1.0.396.isr8 64bit -- 19 Jun 2020
    Copyright (C) 1989-2020 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence and Spectre are registered trademarks of Cadence Design
    Systems, Inc. All others are the property of their respective holders.
    Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
    User: VLSI_ANALOG Host: cad19 HostID: * PID: 27793
    Memory available: 308.9285 MB physical: 3.9726 GB
    Linux : Red Hat Enterprise Linux Server release 6.9 (Santiago)
    CPU Type: Intel(R) Core(TM) i5-2320 CPU @ 3.00GHz
    Socket: Processors [Frequency]
    0: 0 [3001.0], 1 [1600.0], 2 [1600.0], 3 [1600.0]
    System load averages (1min, 5min, 15min) : 0.0 %, 0.5 %, 0.5 %
    Simulating `/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/lowpower/liberate/altos.cad19.T20210519174925563390S0004537.0/sim.sp' on cad19 at 6:12:31
    PM, Wed May 19, 2021 (process id: 27793).
    Current working directory: /home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/lowpower/liberate
    Command line:
    /home/installs/SPECTRE191/tools/bin/spectre -64 \
    Reading file: /home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/lowpower/liberate/altos.cad19.T20210519174925563390S0004537.0/sim.sp
    Reading file: /home/installs/SPECTRE191/tools.lnx86/spectre/etc/configs/spectre.cfg
    Reading file: /home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs
    Error found by spectre during circuit read-in.
    ERROR (SFE-675): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 69: Cannot run the simulation
    because the library file `/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs' included in the
    netlist file `/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/lowpower/liberate/altos.cad19.T20210519174925563390S0004537.0/sim.sp' at line 262
    does not contain a valid section name. Specify a valid section name using the syntax 'include file_name section=section_name' and rerun the
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 72: Cannot open the input file
    './SPECTRE/MM180_LVT18_V113.lib.scs' because either the file name or the directory specified is invalid. Ensure that the specified file exists
    and the path to the file is valid. Alternatively, use the -I <path> command-line option to specify the path to the file and rerun the
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 73: Cannot open the input file
    './SPECTRE/MM180_LVT33_V113.lib.scs' because either the file name or the directory specified is invalid. Ensure that the specified file exists
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 74: Cannot open the input file
    './SPECTRE/MM180_REG18_V124.lib.scs' because either the file name or the directory specified is invalid. Ensure that the specified file exists
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 75: Cannot open the input file
    './SPECTRE/MM180_REG33_V114.lib.scs' because either the file name or the directory specified is invalid. Ensure that the specified file exists
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 76: Cannot open the input file
    './SPECTRE/MM180_ZVT18_V121.lib.scs' because either the file name or the directory specified is invalid. Ensure that the specified file exists
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 77: Cannot open the input file
    './SPECTRE/MM180_ZVT33_V113.lib.scs' because either the file name or the directory specified is invalid. Ensure that the specified file exists
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 81: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 82: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 83: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 84: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 85: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 86: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 90: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 91: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 92: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 93: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 94: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 95: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 99: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 100: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 101: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 102: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 103: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 104: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 108: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 109: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 110: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 111: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 112: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 113: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 117: Cannot open the input file
    './SPECTRE/MM180_DIODE_V113.mdl.scs' because either the file name or the directory specified is invalid. Ensure that the specified file exists
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 121: Cannot open the input file
    './SPECTRE/MM180_BJT_V112.mdl.scs' because either the file name or the directory specified is invalid. Ensure that the specified file exists and
    the path to the file is valid. Alternatively, use the -I <path> command-line option to specify the path to the file and rerun the simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 125: Cannot open the input file
    './SPECTRE/MM180_RES_V133.lib.scs' because either the file name or the directory specified is invalid. Ensure that the specified file exists and
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 129: Cannot open the input file
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 133: Cannot open the input file
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 137: Cannot open the input file
    './SPECTRE/MM180_MIMCAP_V101.lib.scs' because either the file name or the directory specified is invalid. Ensure that the specified file exists
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 141: Cannot open the input file
    simulation.
    ERROR (SFE-868): "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs" 145: Cannot open the input file
    simulation.
    Notice from spectre during circuit read-in.
    "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/lowpower/liberate/altos.cad19.T20210519174925563390S0004537.0/sim.sp" 282: Unsupported Spice2G
    option `accurate' skipped.
    option `nomod' skipped.
    Time for NDB Parsing: CPU = 68.989 ms, elapsed = 251.286 ms.
    Time accumulated: CPU = 223.965 ms, elapsed = 251.29 ms.
    Peak resident memory used = 58 Mbytes.
    Aggregate audit (6:12:31 PM, Wed May 19, 2021):
    Time used: CPU = 224 ms, elapsed = 252 ms, util. = 89%.
    Time spent in licensing: elapsed = 132 ms, percentage of total = 52.5%.
    Peak memory used = 58.1 Mbytes.
    Simulation started at: 6:12:31 PM, Wed May 19, 2021, ended at: 6:12:31 PM, Wed May 19, 2021, with elapsed time (wall clock): 252 ms.
    spectre completes with 39 errors, 0 warnings, and 2 notices.
    spectre terminated prematurely due to fatal error.
  • iamKarthikBK
    iamKarthikBK over 5 years ago in reply to iamKarthikBK
    simulation.
    This means the model file was loaded incorrectly, right?
  • Guangjun Cao
    The wrapper you point the tool to has all sections. you need to include the wrapper using another wrapper, and add the section, eg.
    my_wrapper_tt, inside this file, add,
    //// empty fline
    include  "/home/TSMC/Desktop/UMC180/Designkits/Cadence_6.1/Models/Spectre/MM180_SPECTRE_MAIN_V161.lib.scs"  section=tt
    ... more include lines if needed.
  • iamKarthikBK
    Done!
    But the values I see in the datasheet are still wrong.
    https://gist.githubusercontent.com/iamKarthikBK/4f97b17d7bac915da25328ead6e72e05/raw/1a7ebe9b6b90343786a791c5815586337cadcb5e/liberate2_log.txt is the log file
  • Guangjun Cao
    your simulation stilled. as I suggested, run the standalone spectre on the sim.sp files. follwo the spectre logfile to correct your settings.
    Just to let you know, an issue like you have only takes 0.5hr to solve if you use customer support.
  • iamKarthikBK
    Okay! I'll try it out Slight smile
    Yes I've written to imec.be for help, they've asked me to 'stay tuned'.
    But nevertheless, thank you so much for your patient replies.
