  3. Import data (.csv file) to Cadence
  • Views 14709
Mai M
Mai M over 5 years ago
How can I import data (.csv file) file into the cadence?
I am using Virtuoso spectre.
I am using Python to generate the .csv file from MNIST dataset.
Thank you.
Mai
  • Mai M
    I am using Python to generate the .csv file to MNIST dataset.
    Thank you.
    Mai
    Mai,
    Please read the forum guidelines. This asks you not to post the same question in multiple forums, and also to provide enough information (including software versions) to enable somebody to answer your question. I combined your posts into a single thread to avoid confusion within the forums.
    You are asking about importing "into the cadence'. I have no idea what that means, since there is no tool called "cadence" - and it's completely unclear as to what you are going to use this CSV data for. So please elaborate on what you're intending to do with the data - otherwise you're likely to get an answer that doesn't actually solve your problem.
    Kind Regards,
