  3. Verilog-A: How to trigger event, if input parameter changes...
  • Views 17213
Verilog-A: How to trigger event, if input parameter changes in DC sweep
NZimmermann
NZimmermann over 5 years ago
In my analog testbench, I have a Verilog-A block which is using an integer parameter. This parameter is set in the testbench via a variable in my Maestro view. Now I want to sweep over this variable, when doing DC simulations, i.e a linear sweep with step size 1. However, I can see that this parameter is not updated in the simulations. Instead it always uses the first value of the DC sweep, which seems to be read in by the @inital_step event.
Is there a way to create an event in Verilog-A, when a parameter changes, so that the Verilog-A reacts to this change?
Due to different constraints, it is unfortunately not an option for me to do independent DC simulations with different variable settings, instead of sweeping the variable inside the DC simulations.
    Can you please share the Verilog-A code and explain how you're passing the sweep variable to this parameter? There isn't a way to create an event to do this, primarily because there should be no need to do so - it should just work.
  • NZimmermann
    NZimmermann over 5 years ago in reply to Andrew Beckett
    please find attached a simplified Verilog-A code which can demonstrate my issue. It seems that the @timer paragraphs breaks the DC simulation result. With this paragraph, the variable Vout_val is constantly kept at the starting value of the DC sweep. Without this paragraph the DC sweep simulation works fine. I need this timer for a transient analysis and would not have assume this to influence the DC analysis, but somehow it does!?
    Also, I have attached two screenshots, how I pass the variable from the DC sweep in Maestro to the Verilog-A block.
    Do you understand where this is coming from and have an proposal how to fix this? Thanks a lot!
    Best regards
    Niklas
    Fullscreen VA_sweep_example.txt Download
    `include "constants.vams"
    `include "disciplines.vams"
    module VA_sweep_example(Vout, VSS);
    	output Vout;
    	input VSS;
    	electrical Vout;
    	electrical VSS;
    	parameter integer sweep_param = 0 from[0:31];
    	integer Vout_val;
    	real delay1 = 1u;
    analog begin
    	@(initial_step) begin
    		Vout_val = sweep_param;
    	end
    	@(timer(delay1)) begin
    		Vout_val = Vout_val +1;
    	end
    	V(Vout, VSS) <+ Vout_val*1e-3;
    end
    endmodule
    Andrew Beckett over 5 years ago in reply to NZimmermann
    The initial_step is going to only get fired for the first point in the DC sweep, so that's why it doesn't work (it's nothing to do with the @timer). So Vout_val only gets set once.
    You could add this:
    if(analysis("dc")) Vout_val = sweep_param;
    and that would fix it. I normally don't like using analysis() in Verilog-A code because generally analysis-specific behaviour is incorrect, but it's not that obvious how you'd resolve this otherwise.
  • NZimmermann
    by using analysis() I could resolve my issue. Thank a lot for the hint.
    The @timer function has some influence on my DC sweep simulation. If I have it included in the Verilog-A code, only the starting value of the DC sweep is used for all sweep values. If I remove it from the code, Vout_val is updated with all the "maestro_var" settings of the sweep. See behavior of Vout in the attached plot for both cases. Maybe this is a bug?
    Regards
    Niklas
    Hi Niklas,
    I think this is because with any complex behaviour (actually anything within the code that alters Vout_val) the simulator determines that the changing parameter doesn't affect the operating point. Without the @(timer) then it recomputes the operating point which triggers the initial_step again. I'm not 100% sure, but I think that's what's going on. Might be worth contacting customer support to investigate further to be sure.
