  3. Is there leakage current in Analoglib's cap?
  • Views 1358
yysunj
yysunj over 5 years ago
I wonder whether leakage current occurs in analoglib's cap.
Please tell me about this.
Thank you
yysunj
    No. Assuming that you’re just using the default and not a specific model which models it differently, this uses spectre’s capacitor component which is a pure capacitor (it could be nonlinear but there’s no resistive part - see “spectre -h capacitor “.
    That said, if either end of the capacitor has no path to ground, spectre may add a gmin conductance to ground (default value is 1e-12 Siemens) which you might perceive as leakage. This is added as a convergence aid to help converge floating nodes which otherwise would be completely uncontrolled.
