  3. Question about exporting simulation results to csv format...
  • Replies 8
  • Views 22792
Question about exporting simulation results to csv format, with ocean script
dskang
dskang over 5 years ago
I have a question about ocean script.
As I mentioned on title, I'm trying to do ac simulation and export simulation results to csv file.
In ADLE gui, I could do it by clicking some buttons,
like this.
Now I'm trying to do the same thing with ocean script, I made ocean script by exporting it from ADLE and adding some lines in it. What I've tried until now is: turn on ocnSetXLMode, and read simulation results by getData and put it to csv file by using ocnXlExportOutputView. But in the outfile there wasn't anything. Could anyone tell me what can be fixed or what should I do?
As I'm really novice in ocean so my code maybe seem very weird. By the way, the exit() is for running several script automatically and sequentially.
Thank you in advance.
Dongsuk Kang
    ShawnLogan over 5 years ago
    Dear Dongsuk,
    In the syntax I read for the ocxlExportOutputView(0 function, which is also provided in the On-line support article at URL:
    support.cadence.com/.../ArticleAttachmentPortal
    there is a second argument you are missing if you want to print a specific view. From the manual as shown below, you did not specify for example "Detail" if you want your expressions printed. Please also note that your ocean script does not have any expressions defined to evaluate. You simply defined two output waves - both of which will be complex numbers at each frequency. Did you define any expressions? If you goal is to capture the waveforms in a .csv file, you will need to evaluate rm and ro at each frequency you want using a while or for loop - or alternately to print all - use the ocnPrint() function to send them to a file.
    Shawn
    ocnxlExportOutputView
    ocnxlExportOutputView(
    t_fileName
    t_viewType
    ) => t / t_error
    Description
    Exports the results view to the specified .csv or .html file.
    Argument
    t_fileName
    Path and name of file to which the results need to be exported. Append .htm or .html to the filename to write in HTML format and .csv to write in CSV format.
    If no file extension is specified, a .csv file is created by default.
    The file is saved in the current working directory.
    t_viewType
    Name of the view type that needs to be exported.
    Possible values:
    "" or Current: writes the currently visible view
    Detail
    Detail-Transpose
    Optimization
    Summary
    Yield
    Default value: ""
  • dskang
    dskang over 5 years ago in reply to ShawnLogan
    Dear Shawn,
    Thank you so much for the help. About the cadence support, I still couldn't get license number so I couldn't access to it.
    However, I tried ocnPrint command and it worked. Between ocnPrint and exportoutput view, latter one seems to be more easy to use in my first view (because ocnPrint had many options ...) so I chose it, but I think I was wrong. For now, I think this is enough for me.
    About exportoutputview, I firstly found it at cadence SKILL API finder, but I couldn't find out what each viewtypes means. So I thought letting viewtype at default value will be okay.
    Thank you again!
    Dongsuk
    ShawnLogan over 5 years ago in reply to dskang
    Dear Dongsuk,
    Great! Thank you for letting us know.
    I am glad you have a way to solve your need! I would suggest you contact whomever manages your Cadence tools to ask for your license code. The On-line support portal has a lot of very valuable information if you will be using Cadence tools.
    Shawn
    Hi Dongsuk,
    It's not really a surprise that this doesn't work - you've taken an OCEAN (not OCEAN-XL) script and added a little bit of OCEAN XL around it, but not enough that it is really running as OCEAN XL. For a start, an OCEAN XL script should define tests using ocnxlBeginTest/ocnxlEndTest (you don't have that), and would not run the simulation using run() (which is for OCEAN which is single-test based) but instead use ocnxlRun(). You'd only expect to have the "output table" exported to CSV if you'd actually set up some outputs using functions like ocnxlOutputExpr() - which you haven't either.
    If you're really going to use this approach, I would suggest that you start with an ADE XL or Assembler view, set it up interactively so that you have one or more tests, have some output expression which give scalar results, and then save the OCEAN script from this to see what it looks like.
  • dskang
    Dear Shawn,
    Thank you for the advice, I'll contact the manager and ask for the license code. I was already several time blocked to access to such information and starts to feel I need the one.
    Dongsuk
  • dskang
    dskang over 5 years ago in reply to Andrew Beckett
    Dear Andrew,
    Thank you for the advice, I firstly started with Ocean (exported from ADLE), and I added some OCEAN XL commands to do what I wanted, so I also thought adding OCEAN XL command at OCEAN script might not worked.
    Maybe I should also study on OCEAN XL to find which one will be better for my future work.
    - actually, I tried to find how to export OCEAN XL from ADLE XL like exporting OCEAN from ADLE, but I couldn't find it out. Also I couldn't find manuals like OCEAN. Are these also can be found at cadence support?
    Dongsuk
    Andrew Beckett over 5 years ago in reply to dskang
    In ADE XL you simply do File->Save Script - it's pretty easy to find.
    All the documentation is in your installation; no need to go to support.cadence.com for this - if you click on the Help menu in any Virtuoso window there's a type-in box at the top labelled "Search". In that box, type "OCEAN" and you should find two manuals in this results - the OCEAN Reference and OCEAN XL Reference. You can also find these as PDFs in the IC installation directory:
    <ICinstDir>/doc/oceanref/oceanref.pdf and <ICinstDir>/doc/ocnxl/ocnxl.pdf
  • dskang
    Oh, I see. I thought there might be something like Save OCEAN XL script ....
    Thank you for the other information. I'll take a close look into it.
    Sincerely,
    Dongsuk
