  3. convert selected signed out signal to unsigned
  • Views 13010
abdurrahman0234
abdurrahman0234 over 5 years ago
Hello, my output is 3 bit. It shows range of -4 and 3, naturally as a sıgned. But  output of error cancellation network shows between -3 and +4 in result of noise cancellation with adder and substractor. I want to convert -4 to +4 or means that converting signed 100 to unsigned. How can I do it?.
I try to it with mux, converting 3 bit to 4 bits. But  while half of them signed adding 1, other half unsigned adding 0. It is diffucult because I can not make out<3> bit both 1 or 0. Another solution,may be verilogA. BUT ı failure to write it  as below. Can u help me please?
`include "constants.vams"
`include "disciplines.vams"
module dec (input [2:0] x, output [3:0] y);
wire [2:0] x;
reg [3:0] y;
always @(*) begin
case (x)
3'b001: y <= {1'b0,x};
3'b010: y <= {1'b0,x};
3'b011: y <= {1'b0,x};
3'b100: y <= {1'b0,x};
3'b101: y <= {1'b1,x};
3'b110: y <= {1'b1,x};
3'b111: y <= {1'b1,x};
endcase
end
endmodule
    That code is not Verilog-A, it's Verilog-AMS (actually other than the including of disciplines.vams/constants.vams it's just digital Verilog). So it's not going to work in Spectre (if that's what you're simulating in). Verilog-A can only cope with continuous quantities (such as voltages and currents) and not logic.
    It's not that clear to me what you're trying to do - maybe somebody else understand your request and will be able to answer.
