  3. conflict between schematic_pin view and symbol view
  • Views 13950
sidm
sidm over 5 years ago
Hi All,
I have a testbench with config view. For many of the cells the config view is set to “schematic_pin”. The testbench used to simulate fine earlier but seems there have been some changes to the design and as a results creating the netlist for the testbench is throwing the below error.
ERROR (OSSHNL-912): Netlisting failed because terminal 'AVDD_INT_LV' specified in placed master 'ic_top/PLL_TOP/symbol' does not exist in switch master 'ic_top/PLL_TOP/schematic_pin'.
Should I regenerate the schematic_pin view , if so then how ?
thanks
    I've no idea what a "schematic_pin" view is meant to be. Is it just a schematic with pins only (to effectively omit the block)? If so, then the pins need to match the symbol view and yes you should update the pins to match the symbol view.
    As an alternative (if I've guessed what your purpose of using a "schematic_pin" view is), you could use "bind to open" in the hierarchy editor as a simpler method of omitting the instance or cell from the netlist. This then doesn't require any additional views to be created or maintained.
  • sidm
    sidm over 5 years ago in reply to Andrew Beckett
    Thank Andrew, for the reply. Yes schematic_pin has only the pins in it and purpose is to avoid the transistors to simulate the top block with only the necessary cells that should retain the transistors.
    Since the testbench is old so I am not sure how was the schematic_pin view was created.
    I will try the "bind to open" method.
    Also will be helpful if you can suggest a way to create a pin only view from the schematic ?
    Andrew Beckett over 5 years ago in reply to sidm
    Create->CellView->From CellView (in the schematic editor) and ask it to create another schematic (called schematic_pin). This will then create a schematic with the same pins as your current schematic. You could also do it from the symbol view.
  • sidm
    Thank you very much Andrew.
