  3. PAC simulation issue, "No valid time points are specified...
  • Views 2860
PAC simulation issue, "No valid time points are specified"
venkmanbuster
venkmanbuster over 5 years ago
I am facing a problem with pac simulation. This is the error that I see.
ERROR (SPCRTRF-15168): No valid time points are specified for the sampled analysis `pac'. The analysis is skipped.
To fix the problem, please verify that: 1) Threshold value is within the range of probed signal. 2) Additional timepoints are specified less than the fundamental period.
It doesn't make sense because,
The threshold value that I set is at 0.5*VDD so it is within the range of probed signal (verified with pss plot).
I don't have any additional timepoints specified.
Is there any other reason why this could be happening?
    Andrew Beckett over 5 years ago in reply to venkmanbuster +1
    Please provide: The Spectre version you're using The analysis statements from the spectre netlist so I can see how it's been specified The plot of the signal being used as the trigger for the PAC…
  • venkmanbuster
    Just to be clear, this is in Cadence Virtuoso Spectre simulator.
    Please provide:
    1. The Spectre version you're using
    2. The analysis statements from the spectre netlist so I can see how it's been specified
    3. The plot of the signal being used as the trigger for the PAC analysis (from the time-domain PSS results). Please also make it clear how you've plotted that.
  • venkmanbuster
    venkmanbuster over 5 years ago in reply to Andrew Beckett
    I figured out the reason,
    It has some issue with nport and Spectre X simulator. It worked with an older spectre version with APS.
    That sounds odd. I hope you've reported it to customer support (or maybe it's already fixed in the latest versions?)
