  3. PEX
  • Views 14561
PEX
PCIC
PCIC over 5 years ago
    Which tool (and version) are you using for Parasitic Extraction (and LVS)?
  • PCIC
    PCIC over 5 years ago in reply to Andrew Beckett
    Hi Andrew, thanks for your prompt reply - I'm using Cadence Virtuoso 6.1.7
    Andrew Beckett over 5 years ago in reply to PCIC
    Virtuoso is not a parasitic extraction tool. Nor is it an LVS tool.
  • PCIC
    Oh my bad - got confused after not being able to sleep with this problem. It's Calibre.
    In that case, this is not the best place to ask about this issue. Calibre is not a Cadence tool - it's from Siemens (Mentor). You may be better off asking in on of their forums or to their customer support.
  • PCIC
    Oh okay, will do that. Thank you Andrew.
