  3. Spectre simulator problem
  • Views 12486
Holz
Holz over 5 years ago
Hi everyone,
I'm running a simulation using spectre simulator, the simulation stuck at beginning and in the output log, I find following messages:
What could be the reason for this?  Thanks a lot for help!
Holz
    Usually that just means that you don't have a license and it's waiting for it to be free. You can check which license it's waiting for by going to Setup->Environment and adding "+liclog" into the User Command Line Options field.
  • Holz
    Holz over 5 years ago in reply to Andrew Beckett
    Hallo sir, thanks for help. I sloved this problem
