  3. eval: unbound variable - _simOneStepXmvlog
  • Views 2865
AtaV
AtaV over 5 years ago
Hi everyone,
I am using cadence ICADV 12.3 and ADE XL for my simulations. For some reason, for Verilog simulation, I am facing the error message of "eval: unbound variable - _simOneStepXmvlog" while saving my code. Any thoughts on how to fix this error?
    OK, you've now edited the post to at least give a clue as to which version you're using (you hadn't mentioned that before, so I was having to guess). I think the most likely explanation from checking for other reports of this error is that you haven't got the XCELIUM (or older INCISIVE) release in your path. These two articles cover that:
    https://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=20475032
    https://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=20352847
    I think the error itself may have only occurred in a specific range of sub-versions of Virtuoso, but without going back and checking, I can't confirm that (and the likely solution is that you'd need to fix your UNIX path anyway).
