  3. virtuoso plot issue
  • Views 13774
virtuoso plot issue
sjwprcker
sjwprcker over 5 years ago
For a long time, i got the issue of waveform plotting in assembler (even in old tool, adexl).
Assume i have edited the expression --> VT("net_output"). After simulation, this result show a normal check. So in theory, i can use right-click menu to plot this signal.
However, sometimes this doesn't work, in CIW, it says can not plot "nil".
But, if open result browser, i can locate this net, and plot it, which still works.
Could you do me favor to clarify the reason for this issue?
BR
    I suggest you contact customer support. I can't think of any particular generic reason why something this commonly used would fail in this way. There are a lot of variable factors that might have an influence, such as (and this is not exhaustive)
    • The IC tool sub-version
    • The simulator used and sub-version used
    • The output format
    • Whether the data is marked as saved or not
    • Whether you're sweeping something
    Debugging this in the forum is not very easy and the best solution would be to contact customer support, so I'd recommend you do that.
  • sjwprcker
    sjwprcker over 5 years ago in reply to Andrew Beckett
    The Virtuoso version is IC6.1.8-64b.500.2.
    The simulator is APS.
    The output format is psfxl
    The net is saved
    I am running with multiple corners, like process and temperature.
    BR
    Andrew Beckett over 5 years ago in reply to sjwprcker
    Hopefully you're doing this bit too...
