  3. Outputs to be saved
  • Views 12811
Outputs to be saved
Shashank M Rao
Shashank M Rao over 5 years ago
In ADEL when we select on the schematic and select outputs to be saved ,where  will they be saved (IC618).
Thank You
Shashank
    ShawnLogan over 5 years ago
    Dear Shawshank,
    If I understand your question correctly, the outputs are saved in the spectre simulation results - in whichever format you choose to save the results. The outputs you choose can be viewed in the Results Browser by selecting the output file and viewing them in ViVA. Alternatively, you can access the saved outputs using an ocean script. I hope this answers your question!
    Shawn
