  3. Assembler outputs: change type from implicit to signal
  • Views 13699
HoWei
HoWei over 5 years ago
in the Maestro-Assembler outputs I do have an output signal of type "implicit" (signal, expression, implicit, fault ...) which is no longer used in any expression.
I need to change its type to "signal" to be able to plot/view it.
This is impossible as it tells me in the CIW:   "INFO (ADE-1202): The implicit signal '/I1/MNls/D' cannot be deleted because it is used in other expressions."
How can I get rid of this implicit output signal - I cannot delete it and it is not used in any of the expressions ?
  • HoWei
    Okay, after I restarted Maestro, it was recognized that the signal is no more used in an expression and was removed.
    The above was not correct - It just did not shows the implicit signals.
    Andrew Beckett over 5 years ago in reply to HoWei
    Not sure which sub-version you're using, but I'd start by updating to the most recent. There were a number of issues with implicit signals getting out of date.
    You can also try running:
    maeUpdateImplicitSignals(axlGetWindowSession())
    or
    maeUpdateImplicitSignals(axlGetWindowSession() ?test "testName")
    This function is available from IC618/ICADVM181 ISR6 onwards.
    If that doesn't fix it (and you're using a current hotfix, such as IC6.1.8.500.18 - ISR18) then please contact customers support.
  • HoWei
    HoWei over 5 years ago in reply to Andrew Beckett
    I will try those methods.
    Just for completion - my workaround was to save the outputs in a *.cvs file and to remove the line with the implicit signal - then loaded the *.csv again back into the outputs.
