  3. Dynamic HZ node check issue
  • Views 12050
sjwprcker
sjwprcker over 5 years ago
I have run the dynamic HZ node check, i got the list in the Check/Asserts in the results window. The history item is Interactive.0.
But when i rename the Interactive.0 to XXX, the check result list in Check/Asserts disappear.
How i can recover the list to show and how to avoid such issue in the future?
 - it says "Internal Error: SQL error detected in caa::SqlTbModel::sortFilterFinished - 2 - '[1] no such table: AllCheckAsserts Unable to execute statement' "
 - My virtuoso version is IC618-64b.500.2
BR
    I'm glad you edited your post to add the version used, as I first tried reproducing this and couldn't see the problem. After I saw that you were using ISR2, I tried with that version and I can see the problem. I then did a binary search to find out when it was fixed, and it turns out that I don't see the problem in any version from ISR3 (IC618-64b.500.3) onwards.
    There's a workaround even in ISR2. If (after renaming) you close the history (go over the history name in the tabs at the bottom of the Results window and Right Mouse->Close - or click the red square with a white x in it) and then go to the History tab in the Data View assistant and do Right Mouse->View Results for the renamed history, it will then work again. It seems it just breaks with the rename of the open results - closing and reopening the results again cures it.
