  3. Best way out of 2 ways to generate random voltage source...
  • Views 14800
Best way out of 2 ways to generate random voltage source (DC)?
fastandig
fastandig over 5 years ago
Assume that I have a circuit with 4 transistors (with mismatch enabled) and therefore 4 digital inputs, and 1 digital output. I want to run transient simulation multiple times with Monte-Carlo mismatch (same MC run each time for same mismatch profile of the 4 transistors), for different inputs. The inputs are voltage sources which should have random values either VDD or GND for every transient run. I got to know of two ways to do this: 1) provide an input vector file in ADEXL where I specify input bit-streams for each transient run or 2) write ocean script. Which way would be better? Or if there is any other easier/faster way to accomplish this please let me know. A quick question: is there a command like randint() that I can enter in the global variable section to generate a random number for each transient run? Thank you.
    I'm not entirely sure I get what you want to do, but I think you could probably set your global variable to random(2) (which will then generate 1 or 0 randomly on each run).
  • fastandig
    fastandig over 5 years ago in reply to Andrew Beckett
    Thanks! Further to that question, how can I run transient analysis for multiple runs this way? Normally you write something like "1:10" for some variable to run a simulation 10 times. However if I set my voltage source to "random(2)*vdd_var", won't it only run one time? Because there is no vector specified unlike "1:10". Thank you.
    Edit: Maybe I can create another dummy variable and set to to "1:n". I will try that!
    Andrew Beckett over 5 years ago in reply to fastandig
    Probably the simplest would be to just add some dummy variable (which isn't used anywhere) and have that sweep from 1:1:10. Note I've not tested this to see whether it works!
  • fastandig
    Hah, I got it few seconds before you replied (see my edit :D) Thanks a lot!
  • fastandig
    I tried two ways but the random(2) is always "1". I tried single sweep with dummy variable going from 1:10, and random(2) was "1" for all 10 runs. I also tried with Monte-Carlo using corners and setting the dummy variable to different numbers for each corner. But the random(2) stays at "1". I ran random(2) in the console and it does give random 1 or 0 output. However when running simulations multiple times, it just stays at "1". Any suggestions? Thanks.
    OK, with ADE XL you need to make the expression (say): random(2)+dummy*0
    This is where dummy is the name of your dummy variable that you are sweeping. This seems to work OK.
    With ADE Assembler you have to use a slightly different approach (I think this is due to a bug - I know why, because there's a tension between wanting expressions to be evaluated in the simulator where possible versus evaluating them as SKILL). If you use random(2) in the variable expression, it tries to get spectre to evaluate it and that fails.If I create a little function in my .cdsinit:
    procedure(CCFrand() random(2))
    and then use CCFrand() it seemed to work (once) but then not. So I also have to use CCFrand()+dummy*0 - that then works.
