  3. How to flatten GDS by stream out or Command
  • Views 12883
MollyMeow
MollyMeow over 5 years ago
I used follow skill but  db not flatten
procedure( flatten( lib cell view)
let((cvId)
foreach(via cvId~>vias dbFlattenInst(via 32 t nil nil nil t nil t))
foreach(inst cvId~>instance dbFlattenInst(inst 32 t nil nil nil t nil t))
);procedure
also try the command in Linux but fail
strmout -library try -strmFile try.gds -logFile strmOut.log -summaryFile summary.log -flattenPcells -flattenVias
(error : Command not found)
(use IC5141)
If anyone know the solution/fix for this problem, please let me know..
reguards,
Molly
    Molly,
    Your flatten function won't do anything, because you've got a local variable cvId which is never assigned - so it will be nil. It never opens the cellView! Secondly, in CDB (the database used in IC5141) there is no cv->vias attribute - that was added in OpenAccess.
    The "strmout" command also doesn't exist in IC5141 either - it was called "pipo" and took different arguments (covered in the documentation and I'm sure in many other posts on this forum - there are some "related thread" shown below this post and you can also search for "pipo" in the forums too).
  • MollyMeow
    MollyMeow over 5 years ago in reply to Andrew Beckett
    Thank you for the information.It's really help a lot.
    I am a junior just learned the skill not long ago.
    Sorry for my bad grammar.English not very well..
    Thanks again
    Molly
