  3. Sort function to sort the paths selected using the bbox...
  • Views 12685
Sort function to sort the paths selected using the bbox or beginpt or end pt
kumargbn
kumargbn over 5 years ago
Hi Everyone.
I am writing a code to join two bus kines i.e  horizontal and vertical.
I'm not able to find a way to  to sort the path list with the bBox or Begin Pt oor End Pt. sometime teh selected order is random
Please let me know how to sort a path list using bbox or begin pt or end pt.
Nirmal.
    Hi Nirmal,
    The question really falls down to how would you determine the order? If you have a list of objects, you can use the sort() function with the second argument being a function to compare two objects to determine whether one is less than the other - what "less than" means when comparing two bounding boxes is rather open to interpretation since you have four numbers that come into the equation.
    Assuming that you have a list of pathSegs (rather than paths), then something like this would work (I made this sort based on the beginPt, first point in a point list or lowerLeft of the bounding box):
    procedure(CCFcompareBeginPt(a b)
      let((aPt bPt)
        aPt=a~>beginPt || car(a~>points) || lowerLeft(a~>bBox)
        bPt=b~>beginPt || car(b~>points) || lowerLeft(b~>bBox)
        ; check that either x is less, or if x equal, y is less
        cond(
          (!aPt || !bPt nil) ; check we have a point first
          (xCoord(aPt)<xCoord(bPt) t)
          (xCoord(aPt)==xCoord(bPt) && yCoord(aPt)<yCoord(bPt) t)
          (t nil)
    Then you can use (say the objects were selected):
    sortedObjs=sort(geGetSelSet() 'CCFcompareBeginPt)
  • kumargbn
    kumargbn over 5 years ago in reply to Andrew Beckett
    This works great. Thank you very much.
    Nirmal.
