  3. About User Command-Line Options in Environment Options
  • Replies 7
  • Views 22995
ichiro
ichiro over 5 years ago
Hi all,
I'd like to know how to input several commands into the "User Command-Line Options" box.
For example, +dcopt and +postlayout... and more.
(Explorer-->Setup-->Environment Options-->User Command-Line Options)
Ichiro
    Well, you can just type "+dcopt +postlayout" in the field - am I missing something in your question? That said, I wouldn't put +postlayout since that's already on the Setup->High-Performance Simulation form (it's labelled "Enable Post-Layout Optimization").
  • ichiro
    ichiro over 5 years ago in reply to Andrew Beckett
    Yes, I know the "+postlayout" has been on there, and i tried it with APS simulation. And I also gave the command from Env-command line field then both worked well.
    On the other hand, I need to use "+dcopt" for the convergence so I 'd like to use them together. But I gave the two command from Env-command line with space as separater, now I have an error below:
     '+postlayout/++parasitics' does not work in flat mode. Rerun the simulation by using  +postlayout= legacy_rf instead.
    Ichiro
    ShawnLogan over 5 years ago in reply to ichiro
    Dear Ichiro,
    The concept that Andrew provided is correct Ichiro. However, I think you need to be more specific about the spectre version and options you need.
    The postlayout optimization feature has undergone a number of significant changes over the past few years and the syntax of its options is very dependent on what version of spectre you are using. The error that you are reporting is not related to putting more than one command on the Environment command line options contained in the Environment GUI found by right-clicking on an Assembler test name. For example, as I show in Figure 1 for an Assembler session test I am working with now, I have circled the environmental commands I am including. There are more than 2 options I am including and there are no reported errors in the simulator output log.
    What would be helpful to better understand your error is if you would include the specific spectre command you are using. The command may be found in the spectre.out file located in the results psf directory (alongside the netlist directory). For example, once again using my test as an example, a portion of the spectre command line contained in the spectre.out file shows the following:
    Command line:
    /tools/MMSIM/19.10.428/Linux/tools/bin/spectre -64 input.scs \
    +escchars +log ../psf/spectre.out -format psfxl -raw ../psf \
    +preset=cx +mt=lsf +lqtimeout 0 -maxw 5 -maxn 5 -env ade \
    +lorder MMSIM:PRODUCT +dcopt +disk_check=100e9 -ahdllibdir
    Note each option shown in Figure 1 in the User command line options portion of the Environment Options GUI panel are included as spectre options.
    The post layout command you are trying to include, "+postlayout" , is not directly supported as a user command line option in the most recent versions of spectre and is only supported if you include the syntax for it as:
    +postayout =legacy or +postlayout=legacy_rf
    as shown in Figure 2 from the Cadence On-line support manual at URL:
    support.cadence.com/.../techpubDocViewerPage
    This option is also only available for spectre APS and not for spectre X if you are using it.
    Hence, it is important to understand what simulator you are using and, as a result, what type of post layout optimization you are choosing Ichiro. I hope this helps!
    Shawn
    Figure 1
    Figure 2
    From URL:
    As Shawn said, it would be rather helpful to know:
    1. The spectre sub-version used
    2. The command line for spectre shown in the spectre log file
    I've been doing some digging, and the message about "flat" mode seems to either occur in older versions before some fixes, or using some pre-release technology, or possibly one current case - but I would like to better understand which situation you're facing, and knowing the information above will help narrow it down.
  • ichiro
    Hi Shawn and Andrew,
    Problems that are not straightforward...
    Spectre (R) Circuit Simulator
    Version 18.1.0.169.isr2 64bit -- 12 Oct 2018
    Simulating `input.scs' on "server_address" at 5:13:07 PM, Fri Jul 16, 2021 (process id: xxxxxx).
    Current working directory: xxxxx/netlist
    Command line:
    /tools/Cadence/SPECTRE/SPECTRE18.10.169/tools/bin/spectre -64 \
    input.scs +escchars +log ../psf/spectre.out -format psfxl -raw \
    ../psf +lqtimeout 900 -maxw 5 -maxn 5 +dcopt \
    +postlayout=legacy_rf -ahdllibdir \
    xxxxx/maestro/ExplorerRun.0/sharedData/CDS/ahdl/input.ahdlSimDB \
    +logstatus
    Fatal error found by spectre during command-line options checking.
    FATAL (SPECTRE-475): Option '+postlayout' is not supported in Spectre. Enable APS to use this option.
    spectre terminated prematurely due to fatal error.
    Ichiro
  • ichiro
    ichiro over 5 years ago in reply to ichiro
    This is correct.
    Command line:
    ../psf +aps +mt=1 +lqtimeout 900 -maxw 5 -maxn 5 +dcopt \
    +logstatus
    Fatal error found by spectre during initial setup.
    FATAL (SPECTRE-528): '+postlayout/++parasitics' does not work in flat mode. Rerun the simulation by using +postlayout= legacy_rf instead.
    Andrew Beckett over 5 years ago in reply to ichiro
    The first is clear - you can't run postlayout without APS. Something is rather odd with the second - I can't see why it's saying "flat mode". I'd suggest running with a more recent ISR rather than the base release of SPECTRE18.1, but also can you post the analysis statements and options from the bottom of your input.scs?
