  3. Removing mouse auto default to "Ok" in pop up dialogue within...
  • Views 1949
Removing mouse auto default to "Ok" in pop up dialogue within Virtuoso
blankman
blankman over 5 years ago
Hi All,
I'm hoping this is the right forum for this. I am using Virtuoso within KDE, and am trying to figure out how to stop the mouse auto defaulting to the "Ok" button of popups within Virtuoso. I realize this is only happening within Virtuoso, as no other programs within KDE are showing it. Am I right in saying that this is related to Virtuoso and not KDE? If so, do you know if there is a means to switch it off?
Any help is appreciated. Thanks in advance!
    That's a coincidence (maybe not?) - I have an open case with a customer (from a few days ago) asking exactly the same thing - except they didn't mention the window manager. I am using KDE myself and don't see this - which KDE version are you using? (About in the KDE Control Panel/System Settings will tell you this)
  • Frank Wiedmann
    Frank Wiedmann over 5 years ago in reply to Andrew Beckett
    I am using MATE and I am seeing this, too (for example when I open a maestro view in read-only mode, change something and then close it). However, for me this is a pretty convenient feature, so I would like to keep it. By the way, there was a similar question recently at https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/48085/how-to-turn-off-automatic-mouse-cursor-change-of-position-in-gui-for-popup-messages
