  3. Export simulation results in excel file
  • Views 13589
Holz
Holz over 5 years ago
Hi everyone,
I'm trying to export my simulation results in an excel file and do further analysis, but I get the following error:
*Error* Process ipc:87 failed to export results to the Excel file 'parseJsonToExcel.py error: Json file '/home/hz/csv' does not exist.
What could be the reason for this?  Thanks a lot for help!
Holz
    Holz,
    Which IC sub-version are you using? This error indicates that a temporary file normally used to convert to Excel couldn't be created, but from what I can see in current versions that gets detected and reported clearly - and it's not a file called "csv" either (it creates a temporary .json directory containing the json file for the results prior to converting to Excel)
    So for example for me, if I give a non-writable location, I get:
    WARNING (ASSEMBLER-2206): Results Database: The exportData function failed because the program cannot write to the file /bin/Interactive.1.xlsx0.json.
    Verify that the file is not write-protected and try again.
    (this is with IC6.1.8.64bit.500.19)
  • Holz
    Holz over 5 years ago in reply to Andrew Beckett
    Hallo Andrew,
    I fixed this problem. I can export the excel file into the file system, in which I source the environment file for virtuoso. I got the error because I tried to export the excel file to another file system. But when I export the result as csv file, both file systems work.
    File systems here are /home/ and /Local/, and I source the experiment file in /Local.
    Thanks for help
    Holz
