  3. How can I save the converged values at the nodes after the...
  • Views 13710
How can I save the converged values at the nodes after the last iteration of the time step in verilog-A?
rhanna
rhanna over 5 years ago
There's a possible direct way to print converged values using $strobe.
Is there a way to assign these values to some variable before going to a new time step assuming that this variable is used at a previous equation?
e.g
x = x + const * <variable>
//some equations
V(y) <+ <expression>
 //I want to assign V(y) to <variable> to be used at the first equation.
Thanks in advance.
    I don't really understand from your example what you're expecting it to do (it seems a rather strange requirement from your initial description). Why would you need to do this?
  • rhanna
    rhanna over 5 years ago in reply to Andrew Beckett
    Sorry for the confusion.
    I have a set of equations in the form of:
    x1 = f(h_prev)
    h = g(x1)
    where h_prev is h (the converged value) at the previous time step and initially assumed to be 0, g and f are functions.
    so I need to save the converged value of h at every time step and assign it to h_prev at the begin of the next time step (excluding the initial one)
    [Update]
    I thought about writing the values to a file and then read them but I found a fatal because I'm trying to change the mode of the file. Is there a way to read and write from the same file?
    Andrew Beckett over 5 years ago in reply to rhanna
    That seems very odd, because if you have variable time steps (which is usual with spectre), your function is going to have this strange dependency on the varying timestep. I could understand it if you were using @(timer...) to schedule a regular even and update the variables that way (i.e. like modelling some sampled data system).
    If you really want this to behave this way with a variable time step you could use something like:
    if ($abstime != lastTime) begin
      h_prev=h;
      lastTime = $abstime;
    end
    ... use h_prev in calculations and compute new h
    I've not tested this (mainly because I can't think of an application of it), but I think it should work
  • rhanna
    I agree that the idea is very odd.
    So basically I have got this ODE from a well-trained ML model that predicts a circuit behavior:
    dh_dt(h(t), t) = w2 * tanh( w1 * h(t) + b1) + b2
    where: {w1, w2, b1, b2} is the parameter set of a neural network and it's known
                h(t) is the circuit state at t and dh_dt represents the dynamics (the rate of change)
    I want to solve an IVP at $abstime when h0 (the initial state) is known so I'm using:
    V(h_final) <+ idt( w2 * tanh( w1 * V(h) + b1) + b2, h0, lastTime);
    then, I have an equation where V(ht) is a function of V(h_final)
    where: h, h_final are electrical nodes
               h0 is updated by the last value of V(ht)
    but when I debug, I'm always getting V(h_final) = 0.0, Do you think the problem with the integral?
    Debugging this without seeing the full model is rather difficult (and to be honest I'm unlikely to have time to do that in the coming days before vacation). So the best thing to do with this is to contact customer support where you can share the whole model and a related testbench.
  • rhanna
    Thanks, Andrew for your time and advice.
    One last question if possible:
    I need to do integration on a certain interval, e.g. t1 -> t2, then do some calculation on the output of integration and use the result as an initial condition for subsequent integration e.g. t2 -> t3 and so on
    I tried to do that as follows:
    //initialized ic and dh_dt
    integer ic = 0;
    real dh_dt = 1.591112;
    real dh, h_, h;
    real t_scale = 0.2 * 1e6;
    real t, t_prev;
    analog begin
    t = $abstime * t_scale;
    h_ = idt(t_scale * dh_dt, ic) + dh;
    if (t != t_prev) begin
    // .. some calc. on h_ to get h and new dh_dt
    dh = h - h_;
    t_prev = t;
    end
    But that wasn't efficient, is there a direct way to do so?
