  3. How to set a pre-run MC simulation
  • Views 11979
Hannahyrh
Hannahyrh over 5 years ago
I am using ADE Assembler to run Monte Carlo simulations. The version of Virtuoso is 6.1.8-64b.
Is there a way to run Monte Carlo simulations based on a pre-run Monte Carlo simulation? I have a circuit with 2 different cells connected together. I want to set different numbers of MC points for 2 cells. So, is there a way to run MC for one cell first and then run MC for the second cell based on the pre-run MC simulation results?
Thank you so much!
Sincerely,
Hannah
    Hi Hannah,
    Have you looked at these two rapid adoption kits?
    • Virtuoso ADE Assembler Run Plan Assistant
    • Techniques for Simulating Calibrated Circuits with Virtuoso ADE Assembler
    I think (from what you've described) that Run Plans in ADE Assembler could suit your needs.
