  3. systemVerilog equivalent of ahdlLib?
  • Views 12651
aicdesigner
aicdesigner over 5 years ago
        I was watching the presentation by Daniel Cross on the capacitive DAC model in SV.
It would be nice to run the systemVerilog simulation on a schematic testbench. He has models for caps, resistors, switches, etc.
Is there a Cadence library like ahdlLib that would support the schematic > SV netlist > xrun flow?
    I checked with Daniel, and he's not aware (nor am I) of any Virtuoso library having been built by us containing such models.
  • aicdesigner
    aicdesigner over 5 years ago in reply to Andrew Beckett
    Thanks for checking Andrew.
    I'm putting something together now. I can share what I have when I'm done.
    I'm running into a problem with a model for a switch. I wonder if Daniel or Ron Vogelsong could take a look. It might be an easy one.
    The switch resistance is always coming out OFF - the ctrl input is never seen as 1.
    //systemVerilog HDL for "mySV", "switch" "systemVerilog"
    `timescale 1ns/1ps
    import EE_pkg::*;
    // Shorthand for standard real constants:
    `define Z `wrealZState
    `define X `wrealXState
    module switch(P,N, ctrl);
    inout EEnet P,N;
    input ctrl;
    parameter real res=1000;
    parameter real tr=0; // risetime for analog changes (seconds)
    parameter real vtol=1e-6; // voltage tolerance for iterations.
    parameter real itermax=10; // max iterations at one timepoint.
    parameter real Kinc=1e-6; // fractional change at start of ramp
    real vval, rval;
    real Vval,Rval; // limited versions of vval,rval inputs
    EEnet Pext,Next; // external drive values
    real VPdrv,RPdrv,VNdrv,RNdrv; // voltage & resistance output drives
    bit newP,newN; // flag whether to update P & N drivers
    real VPo,RPo,VNo,RNo; // tolerance & iteration limited output drivers
    real Imeas; // current flowing through this element
    real Tdrv=0; // time of most recent driver updates
    integer Niter=0; // number iterations at this timepoint
    real trt; // risetime value in timescale units
    real vktol; // voltage tolerance dependent on Niter
    initial begin
    vval = 0;
    rval = ctrl === 1 ? res : 1000000000;
    VPdrv=0;
    RPdrv=`Z;
    VNdrv=0;
    RNdrv=`Z;
    vktol=1e-14; // voltage tolerance (adjusts with Niter)
    trt=0; // no risetime at time zero
    #(1step) trt=tr*1s; // risetime converted to timescale
    end
    // System calls to measure external drive seen at each pin:
    reg sie;
    initial sie = $SIE_input(P,Pext);
    initial sie = $SIE_input(N,Next);
    // Update Vval & Rval, including optional risetime and special cases:
    always begin
    if (vval<1e12 && rval>=0) begin // normal drive
    if (trt>0) begin // if risetime included:
    if (Rval===`Z) Rval=1e10; // leaving high-Z region
    else if (vval!=Vval) Vval += Kinc*(vval-Vval); // bump V slightly
    else if (rval<Rval) Rval -= Kinc*(Rval+1); // bump R slightly
    else Rval += Kinc*(Rval+1); // in proper direction
    end
    Vval <= #(trt) vval; // change to new values after risetime
    Rval <= #(trt) rval;
    end
    else if ((vval===`Z) || (rval===`Z)) begin // going to high Z case
    if (trt>0) Rval += Kinc*(Rval+1); // if risetime, bump R value
    Rval <= #(trt) `Z; // change to Z state
    Vval <= #(trt) 0; // V not used when R=Z
    end
    else begin // going to invalid drive
    if (trt>0) Rval += Kinc*(Rval+1); // if risetime, bump R first
    Rval <= #(trt) `X; // change to X state
    Vval <= #(trt) `X;
    end
    @(vval,rval);
    end
    always begin //////// P->N PROCESSING ////////
    if (Rval===`Z || Pext.R===`Z) begin // high-Z drive
    VNdrv <= 0;
    RNdrv <= `Z;
    end
    else begin // normal drive
    VNdrv <= Pext.V-Vval;
    RNdrv <= Pext.R+Rval;
    end
    @(Pext.V,Pext.R,Vval,Rval); // repeat on change to P or input
    end
    always begin //////// N->P PROCESSING ////////
    if (Rval===`Z || Next.R===`Z) begin // high-Z drive
    VPdrv <= 0;
    RPdrv <= `Z;
    end
    VPdrv <= Next.V+Vval;
    RPdrv <= Next.R+Rval;
    end
    @(Next.V,Next.R,Vval,Rval); // repeat on change to N or input
    end
    always @(VPdrv,RPdrv,VNdrv,RNdrv) begin
    if ($realtime>Tdrv) begin // if new timepoint
    Tdrv=$realtime; // save time value
    Niter=0; // init counter
    vktol=1e-14; // first iterations update on any change
    end
    // Update on R change or nontrivial V change:
    if (Niter==3) vktol=vtol; // only update change of >vtol after 3 iterations
    newN = (RNdrv!==RNo || abs(VNdrv-VNo)>vktol);
    newP = (RPdrv!==RPo || abs(VPdrv-VPo)>vktol);
    Niter++; // bump iteration counter
    if (newP|newN) begin // if any signficant change
    if (Niter<=itermax) begin // and if within normal iterations
    if (newP) begin
    VPo <= VPdrv; // update P node driver
    RPo <= RPdrv;
    end
    if (newN) begin
    VNo <= VNdrv; // update N node driver
    RNo <= RNdrv;
    end // Compute measured current flow:
    if (RPdrv+Pext.R>0) Imeas <= (Pext.V-VPdrv)/(Pext.R+RPdrv);
    else Imeas <= 0; // this case should never occur!
    end
    else if (Niter==itermax+1) $display( // message when past iteration limit
    "<EE> ERROR: VRsrc instance %M node%s unconverged at T=%.0fns",
    (newP&newN)? "s P&N" : (newP)?" P" : " N", $realtime);
    end
    end
    assign P = '{VPo, 0, RPo}; // drive output pins
    assign N = '{VNo, 0, RNo};
    assign imeas = Imeas; // return current flow (P to N)
    endmodule
