  3. can't rerun unfinished /error points
  • Views 3223
Holz
Holz over 4 years ago
Hello everyone,
I have strange problem when I tried to rerun error points. In my simulation, I got some points with "sim error", and I have checked output log, there was no error in it.
I tried to rerun these points, but virtuoso closed automatically when it reloaded the result. And I got "Segmentation fault (core dumped) " in linux terminal. I have large memory so memory should not be the problem. Then I updated the spectre simulator to 20.1.0.298.isr9(I used 19.10.541 previously), and ran the whole simulation again. I still got some unfinished points and virtuoso closed again when I reran....
My Virtuoso version is IC6.1.8-64b.500.14 and I'm running transient simulation with 40000 sweep points, and I'm using adexl..
Thanks a lot for help.
Holz
  • Holz
    More Info. I have tried to simulate with few points, 400 total. I broke the simulation at the 200th point and reran the remain 200 points, virutuoso didn't close at this time...
    Andrew Beckett over 4 years ago in reply to Holz
    Please contact customer support. Something odd is going on with your setup - you shouldn't be getting these issues. I advised. you to do that the other day when you reported crashes too.
