  3. Using SystemC models in ADE
  • Views 12430
ChrisEAS
ChrisEAS over 4 years ago
Is there a way/documentation to use SystemC models in ADE-based simulations? I know the RAK about SystemVerilog in ADE-based AMS simulation. Is there a similar RAK about SystemC?
Thanks, Chris
    I'm not sure there's a specific RAK or documentation on doing this, because it's essentially the same as doing it for Xcelium. Perhaps the best thing to do would be to contact customer support so that an application engineer can walk you through it?
  • Frank Wiedmann
    Frank Wiedmann over 4 years ago
    Does https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w00000AHLgGEAX help?
  • ChrisEAS
    ChrisEAS over 4 years ago in reply to Andrew Beckett
    Thanks Andrew. The blow link seems to solve my problem. Otherwise I'll get in touch with the support.
    Chris
  • ChrisEAS
    ChrisEAS over 4 years ago in reply to Frank Wiedmann
    Looks like this could be the solution. Thanks a lot for pointing me to this!
