  3. Update VerilogA outputs during simulation based on values...
  • Views 12019
Update VerilogA outputs during simulation based on values read from from
slim15
slim15 over 4 years ago
For verification of an analog block, I am trying to set up my testbench such that I can change the output of a verilogA input stimulus during transient simulation. The goal is to read a text file at every rising edge of a clock and use the value to change the behaviour of the analog block. The text file will contain only a single line with a single integer value. The version of Spectre is 20.10.isr3
In Spectre X simulation log, I see the CSV file, PGA_GAIN_DATA, being read at the first crossing event with the message "Reading file: /home/c99485/simulation/sandbox/sandbox/maestro/results/maestro/PGA/netlist/PGA_GAIN_DATA.txt". the output bus of the verilogA was also updated. However, all subsequent crossing event did not yield any other messages and it appear that Spectre simulator would just reuse the data that it had acquire from the first read and stored in its memory. Removing or renaming the file after the first instance did not affect the transient simulation.
Is this behaviour expecter? Can I get Spectre to re-read the CSV file and not reuse the data from its memory?
// VerilogA for sandbox02, CTRL_PGA, veriloga
`include "constants.vams"
`include "disciplines.vams"
module CTRL_PGA (VDD, VSS, PGA_GAIN, CLK);
  output [3:0] PGA_GAIN;
  inout VDD, VSS;
  input CLK;
  electrical [3:0] PGA_GAIN;
  electrical VDD, VSS, CLK;
  integer OVR_PGA_GAIN;
  integer fileID, retval;
  real vthres;
  genvar i;
  analog begin
      @(initial_step) begin
         vthres = V(VDD)-V(VSS);
         OVR_PGA_GAIN = 0;
      end
     @(cross(V(CLK) - vthres, 1.0)) begin
        fileID = $fopen("PGA_GAIN_DATA.txt", "r");
        if (fileID > 0) begin
          retval =1;
          while (retval == 1) begin
          retval = $fscanf(fileID, "%d", OVR_PGA_GAIN);
        end
      end
    end
    for (i=3; i>=0; i=i-1) begin
      V(PGA_GAIN[i]) <+ (OVR_PGA_GAIN>>i)&1 ? V(VDD) : V(VSS);
    end
  end
endmodule
    I would expect that you would need to use $fclose to close the file:
      retval =1;
      end
      $fclose(fileID);
    end
    but even that doesn't appear to work in my experiments. There was a discussion about something (sort of) similar in a Cadence Change Request (CCR) 907057, but that was talking about re-reading the file contents within a tilmestep, but this seems to be on separate time steps.
    I suggest you contact customer support. I'm not sure why this doesn't work (other than some optimisation).
