  3. skipping digital registers in analog extracted simulati...
  • Views 11009
skipping digital registers in analog extracted simulations
Mohamayreh
Mohamayreh over 4 years ago
Hallo,
I would like to simulate my design after layout. My design consists of a big analog part and a lot of shift registers that are used to configure the analog part.
Now I finished the layout of all components including analog and registers together. When performing analog extracted using quantus of the top level I can not longer configure the value of the registers since I can no longer set the cell view to veriloga in the config. Therefore I can only simulate the system with registers have a value of zero.
Is there is a way to generated an analog extracted view without flattening the registers as well.
Thanks and regards
Mohammad
    ShawnLogan over 4 years ago
    Dear Mohammed,
    I'm not sure I fully understand how you set your registers if there are no external pins to them. However, I might suggest that you consider black boxing all the digital logic and then you can include a view within the extracted view for the block. Of course, you will LOSE all potential coupling and interaction issues between the two and this may not be acceptable . It is not uncommon to have coupling issues as a result of digital logic traces within an analog block.
    Shawn
