  3. Regarding cadence virtuoso installation
  • Views 13667
Simhadri
Simhadri over 4 years ago
I am new to Linux and trying to install cadence virtuoso (Base & Hotfix IC618 ) in CentOS 8 system. I wrote the bashrc file as below but was unable to access the virtuoso software. Please somebody help me.
export CDS_Netlisting_Mode="Analog"
export CDS_AUTO_64BIT="All"
#export QRC_EXTRACTION_ENABLE
export CDS_LIC_FILE=5280@xxx xxx xxx
# Set up IC (change for Cadence 5 or 6)
export CDS=/root/cadence/installs/IC618
export PATH=$CDS/tools/bin:$CDS/tools/dfII/bin:$CDS/bin:$CDS/share/bin$
export LD_LIBRARY_PATH=$CDS/tools/lib/64bit:$CDS/tools/dfill/lib/64bit
    You don't need to set LD_LIBRARY_PATH. However, I've no idea what the problem is - you didn't explain the symptoms you were seeing.
    I would suggest you contact customer support.
