  3. design/global variable expression
  • Views 1997
sjwprcker
sjwprcker over 4 years ago
I would like to write the design/global variable as: [1:1:10]*(1-x), x is another variable, it is supposed as a vector times some other expression, but assembler reports the syntax error.
Is there any solution can do such a job?
my virtuoso version is IC618-64b-500.18.
BR
    If I assume your variable is called "myvar", then you could do this:
    sweepvar: 1:1:10
    x: whatever you want
    myvar: sweepvar*(1-x)
    Then the variable myvar will have 10 values, 1*(1-x), 2*(1-x), 3*(1-x) etc. You just have to separate the sweep to be a different variable than the combined expression.
