  3. Plotting a function on Cadence calculator that requires...
  • Views 14875
Plotting a function on Cadence calculator that requires the temperature read from x-axsis
Senan
Senan over 4 years ago
I am dealing with temperature to frequency sensor design.
I have simulated the output frequency as a function of temperature in the range from -40 to 85
I need to calculate and plot the sensor accuracy, the is the error as
error in °C = f(T)actual output curve - f(T) ideal curve
approxiamating my sensor output to a linear curve, the ideal curve will be
f(T) = fo-S(T-To)
where fo and To are the frequency and temperature at nominal room condition. S is the average slope
The above variables are very easy to get from simulation, but  my problem is how plot this function [ fo-S(T-To)], it contains the variable T that is introduced by cadence and I don't know how to import it as a variable in Cadence calculator
I am using Cadence Virtuoso version IC6.1.8-64.500.6
Thank you
Regards
    ShawnLogan over 4 years ago
    Dear Senan,
    You should be able to use VAR("temp") to access the temperature from a simulation in a Calculator expression. Have you tried that? This is detailed in the On-line Support article at Cadence URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nVzOEAU&pageName=ArticleContent
    Shawn
  • Senan
    Senan over 4 years ago in reply to ShawnLogan
    Thank you shawn for your help
    that worked with me
  • FormerMember
    FormerMember over 4 years ago in reply to Senan
    Dear Senan,
    > that worked with me
    Excellent Senan! I am happy to read you are on your way. Thank you for letting us know and good luck!
