  3. Format for montecarlo sweep in a *.scs file included with...
  • Views 11519
Format for montecarlo sweep in a *.scs file included with ADE Assembler
greywanderer
greywanderer over 4 years ago
mctrans montecarlo numruns=10 variations=mismatch seed=1 json=yes savemismatchparams=yes \\ <-----UNEXPECTED END OF LINE
                              mismatchscalarfile="*/*/mis_sc_file.txt" \\
                              mismatchparamfile="*/*/mis_par_file.txt" \\
                              dumpseed=yes savefamilyplots=yes {
                                       tran tran stop=5u save=selected
                                       }        <---------- UNEXPECTED END OF BLOCK STATEMENT
Is the above a valid way to include the montecarlo sweep. I see and "unexpected end of line" error on the first line and an "unexpected end of block statement" error on the last line.
Thanks much!
    Presumably the double backslashes are because you're using a stimulus file? I wonder why you keep doing that - it certainly works OK if you use this as a normal included file (with single backslashes):
    Are the double backslashes ending up in the final file that Spectre is reading? If so, I get the errors like you do.
  • greywanderer
    greywanderer over 4 years ago in reply to Andrew Beckett
    I just found out my error. I was including it as a definition file and using double backslashes. Sorry about that. Should have resolved it myself.
