  3. How to formulate the "best fit line" in Vertuoso calcul...
  • Views 2991
How to formulate the "best fit line" in Vertuoso calculator
Senan
Senan over 4 years ago
I am using Cadence Virtuoso version IC6.1.8-64b.500.6
Kindly I would like to ask you how can I formulate the best fit line function in the cadence calculator for the purpose of simulating the sensor output linearity
Thank you for your help in advance
Regards
    There's abBestFit and abFirstLastLine (the first is really a best fit - the second just creates a line between the first and last points) that can be found here: Custom IC Calculator SKILL Function Library
  • Senan
    Senan over 4 years ago in reply to Andrew Beckett
    Thank you Andrew for your fast response and help
    I will try that
    Regards
