  3. How to make auto via feature in cadence avoid slot layers...
  • Views 11682
How to make auto via feature in cadence avoid slot layers since it causes DRC violations?
94d33m
94d33m over 4 years ago
Even though Prevent DRC violations is turned on which does work for metal layers and other vias, but does not work for slot layers?
  • Alex Soyer
    Alex Soyer over 4 years ago
    First you need you need to make sure you have a rule in your techfile defining the min distance in between via and slot layer.
    If not that could be the reason why it does not work.
    Alex
