  3. Measurement across Corners/Sweeps/All in ADE Assembler
  • Replies 11
  • Views 14615
Senan
Senan over 5 years ago
I am using Cadence Virtuoso version IC6.1.8-64b.500.6
I am running some calculations at the result of specific corner. for example, I am calculating the average current at the output of a resistor resulting from temperature change from -40 to 85 °C and at a specific process corner.
I do this by introducing an expression to th ADE Assembler output setup and changing the EvalType to "ALL"
Up to this point, I have had no issue
However, if I add a second corner, the average current will be the average of the output from corner 1 and 2, while my target is to have the average of each individually
I hope I made the status clear
thank you in advance
Regards
    It sounds as if you shouldn't be using EvalType=All but EvalType=Sweeps instead. That will measure across the sweeps, not across everything, and you'll get one result per corner. Andrew
    Andrew Beckett over 5 years ago in reply to Senan +1
    OK, EvalType=Sweeps won't work because you are doing your sweep of temperature within the corners. You didn't mention that - which was rather important. If you add sweeps within corners, it just creates…
    There is also some grouping of runs in ADE Assembler to change parameters in memory when it can. I'm not sure why that would be different between the two runs - I suggest you contact customer support …
  • Senan
    Senan over 5 years ago in reply to Andrew Beckett
    Thank you a lot Andrew,
    yes it solved it and with your nice explanation I understood this tool now
    Best Regards
