  3. Re-running a particular iteration of the montecarlo sim...
  • Views 14624
Re-running a particular iteration of the montecarlo sims
greywanderer
greywanderer over 4 years ago
This question was asked before here.
I ran a montecarlo simulation, with seed=1 and 100 iterations. I now want to run a more detailed simulation on iteration 77. Is there a way to do it? I tried using seed=77 but that does not seem to work.
Thanks much!
    ShawnLogan over 4 years ago
    Dear greywanderer,
    Hmmm...I am not sure what simulator you are using nor what version of virtuoso/spectre/MMSIM you are using greywanderer. If I assume you are using a relatively recent version of Assembler to submit your Monte carlo simulation, method 2 of the Cadence On-line support article at URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009Eq0VEAS&pageName=ArticleContent
    details how to reproduce a specific Monte Carlo simulation to do further analysis or debugging. You need to indicate not only the seed, but also the starting point and the statistical method as the article notes. I hope I fully understood your question and my assumptions about your simulation methodology/version are correct....and most importantly.... this helps provide some insight greywanderer.
    Shawn
    Andrew Beckett over 4 years ago in reply to ShawnLogan
    My assumption is that greywanderer wants to know how to do this in a spectre netlist as many questions previously have involved including Netlist-level analysis statements.
    You wouldn't change the seed - in fact there's very little reason to change the seed unless you want to force different results. Instead you would set firstrun=77 numruns=1 on the Monte Carlo analysis. See "spectre -h montecarlo".
  • greywanderer
    greywanderer over 4 years ago in reply to Andrew Beckett
    Yes, it makes sense that its not the seed. Because that would change the starting point of the random number sequence. The firstrun according to the spectre help is the "starting iteration number" and wasn't clear to me before that it is the iteration of the random number generator with a given seed. So it makes sense that with the same seed I should set firstrun=77 and numruns=1.
    Shawn, Thanks for your response. This question was for netlist-level analysis statements as Andrew assumed.
    Best regards,
    Murthy
    ShawnLogan over 4 years ago in reply to greywanderer
    Dear greyeanderer,
    > assumed.
    Rats! Sorry for not fully understanding your context! I hope my information did not confuse you or waste your time!
    Nevertheless, I thank you Andrew for stepping in and providing the correct answer, and thank you greywanderer for letting me know I misinterpreted your question and use!
    Shawn
  • greywanderer
    greywanderer over 4 years ago in reply to ShawnLogan
    Not at all..
