  3. Function to add scs file to model libraries
  • Subscribers 136
  • Views 15555
dragank
dragank over 5 years ago
HI all.
I am using IC6.1.8-64b.500.10
I am checking, but with no success so far.
Is there public function to add scs file to model libraries programmatically so it can be shown here:
or here
Thank you in advance
Dragan
    Use asiSetEnvOptionVal with either modelFiles (for the top) or definitionFiles for the bottom. See this post.
  • dragank
    dragank over 5 years ago in reply to Andrew Beckett
    When applied it adds new scs file when listed from CIW, but in GUI window it is not listed.
    Best regards,
    Dragan
    Andrew Beckett over 5 years ago in reply to dragank
    If you give the first argument as asiGetTool('spectre), it will update for new ADE setups (it won't affect any existing states/maestro views). If you have existing setups, you need to pass a session (e.g. asiGetCurrentSession() ) as the first argument.
  • dragank
    Applied and working on selected tests.
    Thank You.
    Best regards,
    Dragan
  • dragank
    dragank over 5 years ago in reply to dragank
    Actually it adds .scs file to model libraries of last test.
    I am using IC6.1.8-64b.500.10.
    If this makes things clearer, when I apply:
    asiSetEnvOptionVal(asiGetCurrentSession() "modelFiles" ; definitionFiles
      append(
      asiGetEnvOptionVal(asiGetCurrentSession() "modelFiles") ; definitionFiles
        list(
          list(outFileName)
    to:
    new scs file is added to "tran_noise test".
    At first it seemed to me it adds it to selected models, but it is not.
    Is there a way to supply test name or something similar that new .scs file shoud be added to it's libraries.
    Best regards,
    Dragan
    Dragan,
    OK, you didn't mention that you were using a multi-test environment such as ADE Assembler.
    You can do this for a specific test by doing:
    testSess=maeGetTestSession("testName")
    asiSetEnvOptionVal(testSess"modelFiles" ; definitionFiles
      append(
        asiGetEnvOptionVal(testSess "modelFiles") ; definitionFiles
            list( ; if setting definitionFiles don't include this extra list
              list(outFileName)
    If you are using ADE XL then you'd have to use:
    sevSess=axlGetToolSession(axlGetWindowSession() "testName")
    testSess=sevEnvironment(sevSess)
