  3. Reset layout celview size
  • Views 11279
gparasiliti2
gparasiliti2 over 4 years ago
Sometime happens that we set some field of a pcell in meters, after a while we can return to edit the cellview to fix the wrong value, but something in the cellview changes and it seems that the cellview is more larger in size than the real dimensions.
The message reported in the CIW is similar to this: "The coordinate 3e+11 is over the max 2.14748e+09 and 2.14748e+09 is used.", and it needs a long time to open the cellview also if it's a small block.
Please, could you help me to reset the cellview?
Giuseppe
    Giuseppe,
    I don't really know what you mean by "reset the cellview" nor do I really understand what you've done here. Perhaps you should contact customer support so you can actually show somebody what you've done?
