  3. Spectre Transient Noise Simulation (Transistor sources,...
  • Views 16179
Spectre Transient Noise Simulation (Transistor sources, analytical behaviour)
priyeshs
priyeshs over 4 years ago
I am running transient noise analysis in spectre. Upon adding the noise sources, the variance of total noise increases. But when I add some more transistors to the circuit with an intention to observe more noise (amplified) at a node, I actually do not see any effect as if noise is not being generated from the transistor sources but being generated from somewhere else and irrespective of the size of the circuit (also, noiseon parameter doesn't seem to be working). I already check all existing queries on Spectre transient noise analysis in cadence/eda forums and could not get any help from them. I will really appreciate your help on this.  Pasting my transient simulation commands form the spectre netlist below:
Circuit is simple cross-coupled inverter. observing noise at Q (output node). And when I add additional circuitry (or transistors at Q node, the noise should increase, right?)
simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=50.0 tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 digits=5 cols=80 pivrel=1e-3 sensfile="../psf/sens.output" checklimitdest=psf
tran tran stop=100p errpreset=moderate method=trap noisefmax=500G noiseseed=1862 noisescale=1 write="spectre.ic" writefinal="spectre.fc" annotate=status maxiters=5
Model file comands for noise below:      (model file is from ptm asu 16nm lstp : http://ptm.asu.edu/modelcard/PTM-MG/modelfiles/lstp/16nfet.pm.      http://ptm.asu.edu/modelcard/PTM-MG/modelfiles/lstp/16pfet.pm. )
* noise *
+ef = 1
*========================== 1/f ===========================*
+lintnoi = 0 em = 41000000 noia = 6.25e+039 noib = 3.125e+024
+noic = 87500000 ntnoi = 1 tnoimod = 0
Thanks!
    Please can you provide the entire netlist (input.scs)? That way at least I have a chance to run some experiments.
    By the way, sending me a friend request on the forums won't get your question answered more quickly - if it was urgent, you should contact customer support. I look at things in this forum in my spare time (it's not part of my job at Cadence to answer anything here), and this week I've had very little spare time...
  • priyeshs
    priyeshs over 4 years ago in reply to Andrew Beckett
    Hi Andrew! Thank you for your reply. I'm sorry for this inconvenience. I can contact the support as well. Please find below the netlist and model files link. Please let me know if anything else is needed. Thank you so much for your help. Regards, Priyesh
    Model files: http://ptm.asu.edu/modelcard/PTM-MG/modelfiles/lstp/16nfet.pm     http://ptm.asu.edu/modelcard/PTM-MG/modelfiles/lstp/16pfet.pm
    //spectre netlist
    simulator lang=spectre
    global 0
    include "local_model_file_path/nfet.pm"
    include "local_model_file_path/pfet.pm"
    //baseline CCI
    M0 (Q PCH VDD VDD) pfet nfin=2 l=16n
    M1 (Qb PCH VDD VDD) pfet nfin=2 l=16n
    M2 (Q Qb VDD VDD) pfet nfin=2 l=16n
    M3 (Qb Q VDD VDD) pfet nfin=2 l=16n
    M4 (Q Qb netn 0) nfet nfin=1 l=16n
    M5 (Qb Q netn 0) nfet nfin=1 l=16n
    M6 (netn PCH 0 0) nfet nfin=1 l=16n
    //uncomment M7 and M8 to connect these transistors to nodes Q and Qb with an idea of seeing more noise at Q and Qb
    //M7 (Q 0 0 0) nfet nfin=50 l=16n
    //M8 (Qb 0 0 0) nfet nfin=50 l=16n
    V0 (VDD 0) vsource dc=0.85 type=dc
    V1 (PCH 0) vsource type=pulse val0=0.85 val1=0 period=1n delay=0 rise=5p fall=5p width=495p
    tran tran stop=1n errpreset=moderate method=trap noisefmax=200G noiseseed=5746 noisescale=2 write="spectre.ic" writefinal="spectre.fc" annotate=status maxiters=5
    Andrew Beckett over 4 years ago in reply to priyeshs
    If you're going to contact customer support too, then I won't spend time on it here otherwise we'll be duplicating effort - that makes no sense.
  • priyeshs
    Hi Andrew, I am not contacting customer support since you wrote you can run some experiments. If you are unavailable then I will contact them. Since you are already in thread I feel it will be much faster to get help from you. Thank you. Regards, Priyesh
    I spent a few minutes trying to figure out what's happening here. The circuit here seems rather unstable - try running for 10ns (with or without noise, and with or without the extra transistors). The extra transistors are off, and effectively are capacitors on the output - I don't think they contribute much to the noise but they do damp the output because of the capacitance (so actually the noise reduces). I did also try running pss and pnoise to check noise contributors but the circuit is behaving strangely when settled (if you can get it to converge) - so I wasn't entirely convinced that I could draw too many conclusions.
    The device models seem to have default values for every noise parameter (compare with "spectre -h bsimcmg" which is the model used here).
    Not really sure what you're expecting (and after all, these are fictional models so I'm not convinced anyone has taken a huge amount of care over them).
    If you need more, please contact customer support - it's not obvious to me whether what you're expecting is realistic (and I don't have time to debug your circuit, however small it might be).
