  3. Remote Host (Output Log Update Rate)
  • Views 11314
Shico90
Shico90 over 4 years ago
We have recently switched to simulating on a remote machine instead of locally. It works fine in terms of simulation but we have noticed that the output log update rate is much lower, also in ams simulation we can't view the results while the simulation is running (only happens on remote host).
Pinging the remote host gives 1.5ms ping time so it looks okay.
Is there a way to improve the output log update rate we get back and view the simulation results while simulation is running?
Sherif
    Sherif,
    I don't think I'd expect that to change and I'm not aware of any controls over this. I suggest you contact customer support.
  • Shico90
    Shico90 over 4 years ago in reply to Andrew Beckett
    Okay.
    Thank you. I'll contact them.
    Sherif
