  3. Monte carlo simulation question
  • Views 11295
Holz
Holz over 4 years ago
Hi everyone,
I have a 16 bits adder circuit, and for each adder, it has three input ports: a,b and carry_in. I want to do monte carlo simulation(sweep these three input values) to analyze how the delay distributes.
So, the value of the inputs of each adder should be either 0 or VDD, I have no idea how to do this since there are no swept values, and if I write "vary ***" in "process", it will not work.
Thanks for the help!
Holz
    Holz,
    You could create a spectre file like this:
    parameters VDD=3.3 \
      dist0=0 bit0=(dist0>0?VDD:0) \
      dist1=0 bit1=(dist1>0?VDD:0) \
      dist2=0 bit2=(dist2>0?VDD:0) \
      dist3=0 bit3=(dist3>0?VDD:0)
    statistics {
        process {
    	vary dist0 dist=unif N=1
    	vary dist1 dist=unif N=1
    	vary dist2 dist=unif N=1
    	vary dist3 dist=unif N=1
    Then you could reference the bit0/bit1 etc on your input sources:
    Vb0 (b0 0) vsource dc=bit0
    Vb1 (b1 0) vsource dc=bit1
    Vb2 (b2 0) vsource dc=bit2
    Vb3 (b3 0) vsource dc=bit3
    Hope that helps? Given that you can't have discrete distributions, I've just created uniform distributions between +/-1 for each and then the ternary expression on each "bit" parameter translates that to VDD or 0 depending on whether the dist parameter is positive or not.
  • Holz
    Holz over 4 years ago in reply to Andrew Beckett
    Thanks, Andrew, this really helps!
