  3. supported psf format different between IC617 and IC618?
  • Views 12287
kkdesbois
kkdesbois over 4 years ago
Is the psf format supported for OP annotation different between IC617 and 618?
I'm using a 3rd party simulator and OP annotation setup is OK when using IC617 but I get the following message when using IC618 :
WARNING (OCN-6040): The specified directory does not exist, or the directory does not contain valid PSF results.
Ensure that the path to the directory is correct and the directory has a logFile and PSF result files.
The results directory contains exactely the same files when it results from a simulation either from IC617 or IC618.
Laurent.
    No, it hasn't changed.
    I would contact customer support (maybe for the third-party simulator first).
  • kkdesbois
    kkdesbois over 4 years ago in reply to Andrew Beckett
    Thank you for the answer.
    Meeting with the 3rd party support next afternoon. Let's see.
