  3. Can liberate use an encrypted hspice model?
  • Replies 9
  • Views 15583
sherryshe
sherryshe over 4 years ago
Hi, problem again, can liberate use an encrypted hspice model? thanks in advance!
  • Guangjun Cao
    Guangjun Cao over 4 years ago
    Hi sherry,
    It should be possible. Do you have a problem?
    Guangjun
  • sherryshe
    sherryshe over 4 years ago in reply to Guangjun Cao
    Thank you for your reply!
    It would be OK while reading encrypted spectre model, but when I change model from .scs to .l as well as change  -extsim from spectre to hspice, errors would show up like this:
    ERROR (SFE-841): "/home/shexy/liberate/MODELS/newmodel/***_encrypted.l" 241: Unexpected character `$' in netlist.
    ERROR (SFE-1806): "/home/shexy/liberate/MODELS/newmodel/***_encrypted.l" 243: `o' ( first char of `o' ) is not a valid SPICE element type.
    ERROR (SFE-874): "/home/shexy/liberate/MODELS/newmodel/***_encrypted.l" 245: Unexpected closing bracket.
    ERROR (SFE-1768): "/home/shexy/liberate/MODELS/newmodel/***_encrypted.l" 246: Expression is missing a terminating quote character.
    It seems that the model is not read, right? How can I fix it?
  • Guangjun Cao
    Guangjun Cao over 4 years ago in reply to sherryshe
    Do you mean it works with Spectre model but not Spice model? This is more like a simulator/hspice related issue. Unfortunately, if can't help you with other vendors' tool.
    Why do you have to run hspice? You will not get the performance benefit from Liberate. You may still use spice model when using Spectre as simulator. However, it will be good if you use Spectre model as well.
    You need to check the read_spice command, does it have correct -format option. Also, make sure your model wrapper has the right language settings.
    Guangjun
  • sherryshe
    Yes, Actually I have to use hspice model now.. I’m not sure the errors come from my settings or just hspice related issue. Would you please help me check? Here is the partial char.tcl.
    set_var extsim_model_include ${rundir}/MODELS/include_models1802.sp
    foreach cell $cells {
        lappend spicefiles ${rundir}/NETLIST/${cell}.pex.netlist
    read_spice $spicefiles
    char_library -extsim hspice -ccs -ecsm -cells ${cells}
    include_models1802.sp is like:
    .lib 'newmodel/****_encrypted.l' TT
    When I run the tcl, errors show up like this:
    Anyway, thank you a lot!
  • Guangjun Cao
    It is hard to tell when you only provide a portion of the logfile. some other warnings may also cause such error. Here are my suggestions,
    1. cd into the altos.** directory, run hspice on the sim.sp. The error indicates your hspice does not run successfully. you need to following the logfile information to make it run successfully. This maynot be related to Liberate.
    2. switch to Spectre simulator. you can still run Spectre using hspice model.
    a. add 'read_spice ${rundir}/MODELS/include_models1802.sp' after 'set_var extsim_model_include'
    b. if you see any warnings on leaf cell in the logfile, add define_leafcell command for every device/model used in your netlist.
    c. use the procedure in '1' to debug your settings for model file and netlist.
    d. you may need to use 'set_var ski_enable 0' for debug runs.
  • Guangjun Cao
    Guangjun Cao over 4 years ago in reply to Guangjun Cao
    One of our Spectre experts pointed out that encripted hspice model is not suported by Spectre. So, please ignore option-2 in my previous comments. 2a/b may still be worth trying.
    Guangjun
  • sherryshe
    I see, thank you for your reply!   Slight smile
  • Guangjun Cao
    You are welcome.
    Have you solved the issue?
  • sherryshe
    Yeah, I asked them for a feasible encrypted spectre model...
