  3. print montecarlo correlation table
  • Views 11347
Michael Figueiredo
Michael Figueiredo over 5 years ago
Hi, is it possible to use the "Print Correlation" function from adexl for montecarlo simulations in ocean.
Just like "noiseSummary" returns the dominant noise sources, I would like a print correlation for dominant mismatch sources.
Is this possible ?
Thanks.
    Not sure there's an explicit function for this, but if you're running an OCEAN XL script you should be able to re-open the history in ADE XL (or Assembler) and then do it from there. If that's not what you want, I suggest you contact customer support as it may need an enhancement request.
