  3. PVS Extraction Issue - Not finding PVS or QRC tab in Virtuoso...
  • Replies 13
  • Views 11165
PVS Extraction Issue - Not finding PVS or QRC tab in Virtuoso Layout to do parasitic extraction
vaishakprathap
vaishakprathap over 4 years ago
I am using AMS 0.35um (C35B4C3) Process Hit Kit.
I finished a layout in Virtuoso Layout L. It does not have a schematic associated with it. I want to extract the layout and run simulation to ensure proper working.
The issue faced is that I do not know how to extract the layout. I do not find a PVS or QRC tab in Layout Window to do extraction. I went into the Launch-->Plugins tab but was unable to find a PVS tab.
The Cadence version is: IC6.1.8-64b.500.12
The Assura version is: sub-version 4.1_USR6_HF11
Checking for PVS home and version returns the following:
vaishakp@moose2(9-5:01am)$ env | grep PVS_HOME
PVS_HOME=/util-cse/cadence/ic/
vaishakp@moose2(10-5:04am)$ which pvs
/sbin/pvs
A deadline is approaching in a week and would be gratetful for any help.Kindly guide me on how to extract the layout without the schematic using PVS or QRC and run simulation on an extracted netlist....
  • vaishakprathap
    In the AMS Hit Kit they show the paths that need to be set up for extraction. The snippet is shown below:
    # Cadence EXT / QRC path. Replace the /cad/cdsext15_26_s603 string by your installation path
    setenv PVS_HOME /cad/cdsext15_26_s603
    set path=($path $PVS_HOME/bin)
    if ( $?LD_LIBRARY_PATH == 0 ) then
    setenv LD_LIBRARY_PATH $PVS_HOME/tools/lib:/lib:/usr/lib
    else
    setenv LD_LIBRARY_PATH $PVS_HOME/tools/lib:${LD_LIBRARY_PATH}
    endif
    In my .aliases file we have the PVS_HOME path set up. Then why am I not able to see a PVS/QRC tab in CADENCE Virtuoso layout to do extraction? As shown in the screen shot there is no option to run Extraction under Assura Tab. But we ran DRC with Assura.....
    Andrew Beckett over 4 years ago in reply to vaishakprathap
    First of all, there's no need to set LD_LIBRARY_PATH for PVS. I initially wondered whether it was because you had /sbin in your path before the PVS binary directory (I assume) but that works OK because the detection is done by looking in all the paths in $PATH and checking for the presence of a few executables such as "lvsbrowser".
    What do you get if you type "which lvsbrowser" and "which pvsnvn" in the terminal which you started Virtuoso from?
  • vaishakprathap
    vaishakprathap over 4 years ago in reply to Andrew Beckett
  • vaishakprathap
    Both the commands show Error eval Unbound variable as shown in the snapshot
  • vaishakprathap
    Shown below is the actual paths for the PVS_HOME:
    setenv PVS_HOME /util-cse/cadence/ic/
    else
    endif
    I didn’t ask you to type it in the Virtuoso window (CIW) because that would fail with an error because what I asked you to type was not a SKILL command.
    Please type it in the terminal window as I asked.
  • vaishakprathap
  • vaishakprathap
    vaishakprathap over 4 years ago in reply to vaishakprathap
    Sorry for the misunderstanding. I typed the commands in the terminal from which I opened  Virtuoso as shown in the screenshot. Nothing seemed to happen....
    That's because you have run "ams_cds" in the foreground and so it's blocking the terminal - so typing anything in at the terminal won't do anything because the "ams_cds" program is running. That's pretty basic UNIX knowledge...
    Anyway, you'd need to run this in the terminal when you're not running "ams_cds" at the same time, or you have run it in the background by doing:
    ams_cds -tech c35b4 &
    (the ampersand backgrounds the job, giving the terminal prompt back again).
  • vaishakprathap
    Thanks for your time. I am new to UNIX enviornment. So pardon my limited knowledge. I had run the commands you mentioned from the directory from which I run CADENCE from. They also had returned "Command Not found" responses as shown in the screenshot below:
