  3. Several problems with interfacing Spectre through Matla...
  • Subscribers 133
  • Views 5614
Several problems with interfacing Spectre through Matlab
FormerMember
FormerMember over 4 years ago
Dear Community
I am trying to use Matlab's Spectre toolbox to read out simulation results. I am using Matlab 2021a and Spectre version 20.10.186
In particular, I want the following outputs:
  • Many operating point parameters from all transistors in the schematic
  • The AC waveform from a current signal, taken from the terminal "/R0/PLUS"
  • The total output noise (as waveform in V/sqrt(Hz)) from a linear noise analysis where the output nodes are named "/Ip" and "In", respectively.
  • The loop gain from an iprobe
When I type the command
cds_srr(result_dir)
I get the following output:
PSFversion: 1.00
dcOp-dc (dc).
dcOpInfo-info (info).
ac-ac (ac).
tran-tran (tran).
finalTimeOP-info (info).
modelParameter-info (info).
element-info (info).
outputParameter-info (info).
designParamVals-info (info).
primitives-info.primitives (info.primitives).
subckts-info.subckts (info.subckts).
variables (design_variables).
ans =
12×1 cell array
{'dcOp-dc' }
{'dcOpInfo-info' }
{'ac-ac' }
{'tran-tran' }
{'finalTimeOP-info' }
{'modelParameter-info' }
{'element-info' }
{'outputParameter-info' }
{'designParamVals-info' }
{'primitives-info.primitives'}
{'subckts-info.subckts' }
{'variables' }
Problem 1:
I cannot get any DC operating point parameter. When I use
cds_srr(result_dir,'dcOpInfo-info','M1.m1.gm')
I get the message:
Error: The special signal is not exist.
One or more output arguments not assigned during call to "cds_innersrr".
Error in cds_srr (line 20)
sig = cds_innersrr(dirname, dataset, signame, verbose);
In the result brower, I can see that the operating points are there. How do I access them?
Problem 2:
Where is the result of the noise simulation stored? There is a folder called "noise" in the result brower, and a corresponding signal called "out" (which is the waveform I want in Matlab). But cds_srr does not return any noise dataset.
Problem 3:
Same for the stability analysis. There is a folder called "stb", but no corresponding dataset.
Problem 4:
I get the following output from the AC analysis when using cds_srr(result_dir,'ac-ac')
Total: 22 properties
'PSFversion' 'BINPSF creation time' 'PSF style' 'PSF types' 'PSF sweeps' 'PSF sweep points' 'PSF sweep min' 'PSF sweep max' 'PSF groups' 'PSF traces' 'simulator' 'version' 'date' 'design' 'analysis type' 'analysis name' 'analysis description' 'xVecSorted' 'tolerance.relative' 'start' 'stop' 'operating point producer'
Total: 2 type(s) of signals
Signal type: V Data type: Complex
'net2' 'net3'
Signal type: I Data type: Complex
'M0:1' 'V0:p' 'V1:p'
In the result browser, there are much more signals saved in the ac folder (including my ""/R0/PLUS" signal which I want). Why can I not see them in Matlab?
Thank you for your help.
Best wishes,
Dominik
    Hi Dominik,
    1. This should be 'M1.m1:gm' (you need to use colon to access the final part when it's operating point data)
    2. For me this was: out=cds_srr(result_dir,'noise-noise','out')
    3. cds_srr(result_dir,'stb-stb','loopGain') to get the loop gain, or cds_srr(result_dir,'stb-margin.stb','phaseMargin') (or 'gainMargin')
    4. Not sure - do you see more if you use cds_srr(result_dir,'ac-ac').I to see all the current signals? It seems to work for me (I'd expect the resistor current to probably end up being R0:1 as you get the netlist names)
