  3. Prevent Maestro from reporting undefined design variabl...
  • Subscribers 133
  • Views 5531
Prevent Maestro from reporting undefined design variables
FormerMember
FormerMember over 4 years ago
I have a cell view which contains standard elements (resistor, capacitor,...) with variables. I want to set these variables with a model file. However, everytime when I start the simulation, Maestro reports these variables as undefined. If I continue, the simulation fails, because the empty variables are added to the 'parameters' statement, which comes after my model file.
Is there a way to prevent Maestro from automatically adding undefined variables? I found the 'findVariablesSkip' global variable in the documentation, which seems to do exactly what I want (ignore variables in extracted cell views, if the cell view contains the 'extractionCreatedBy' property). However, even if I set it to 'extracted' or 'parasitic' and add the 'extractionCreatedBy' property to my cell view, Maestro still complains about the variables.
Best regards
Paul
  • FormerMember
    For now I found a workaround by defining the variables under a different name in the model file and set the automatically added variables in Maestro to these. In this case no empty variables are generated, but this is not really a good solution, because one has to always do this for each testbench and test. Does anyone have another idea to solve this?
    Andrew Beckett over 4 years ago in reply to FormerMember
    Hi Paul,
    Please contact customer support.
  • FormerMember
    I found a workaround which seems to solve my problem. Instead using a variable, I use a constant function in the expressions. I then define the functions in a model file. However, I will also file a support request, asking if it is also possible to do this with variables.
    I investigated a little bit further and it seems the issue is not caused by Maestro, but during the netlisting process. Even if I netlist the cell view directly, the empty variables are always added.
